Question about Drills
REMOVING THE CHUCK ON A AEG BSB 18 STX-R ELECTRIC DRILL
I NEED TO REMOVE THE CHUCK AND GEARBOX
stug_57u
  • 99 Answers
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Posted on Oct 25, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
  • 3 Answers
SOURCE: remove a chuck from a skill drill
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Uncscrew screw CLOCKWISE until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 25, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
How do I remove the chuck of a Metabo BST 12?
First you will need to remove the "Set Screw" in the middle of the chuck. this screw is reverse thread. after the screw is removed the chuck is standard thread you it can simply be unscrewed.
Jun 04, 2014 | Metabo Drills
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
HOW TO REMOVE KEYLESS CHUCK FROM MAKITA 6271D
Open the chuck so you see a screw insite and turn the screw 251468-5 clockwise to remove. in first place , have a full loaded battery and shift the machine so it turns you see the chuck counterclockwise so the same direction as you will lose a drill.
2. Now take the greatest possible Allen key fitts in the chuck 10 - 13
and place the short site of the key in the chuck and the long side you set in a bech screw strong fixating it , and then on the same time to push the powerswitch in the first gear turn your tool with both hands in the same direction agains the clock try for 2 seconds normaly it will lose. BUT !!!
3 , whenn you will not risk any damage you should open the 4 screws of the gearbox until you see a little shaft retaining ring of the drill spindle warning (THERE IS NO MANUAL of the planet transmission gearbox ) but its very good and possible to do .when you are handy but there are a few little balls and little axles and gears but if you lose the shaft retaining ring you can set the drill spindle in a bench screw, warning use not the full length because the round part is what is made as a part of a bearing one centimeter of the spindle of the chuck can you set in the bench to prevent damage of the bearing point or the spindle of the gearbox is become useless.
Succes
Apr 05, 2014 | Makita Drills
Bosch GSB 18 VE-2 gearbox jammed
The screw inside the chuck of most drills is backwards from what you would think. You will need to rotate it clockwise to remove.
Mar 11, 2014 | Drills
How do I replace the chuck in my drill? It is making a grinding noise.
Chucks DON'T make grinding noises!!!!!
The grinding noise is probably coming from the REDUCTION GEARBOX which is located behind the chuck [the shaft upon which the chuck is mounted comes out of the gearbox].
There are usually four (4) screws mounting the gearbox housing/cover onto the motor/handle section of most drill/drivers.
The cause of most grinding nioses originating in the gearbox is lack of lubricating grease between moving parts.
Jun 02, 2013 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Sum think rong with cluch chuck not turning motor is running
sounds like a strpped gear or broken shaft. look in the gearbox where the motor shaft goes into the gearbox. if that is ok go to the where the chuck spindle comes out of the gearbox.
Aug 31, 2010 | Makita 15/16" Rotary Hammer, SDS, 3-mode,...
How to replace chuck for DC759
First of all, open the jaws of the chuck and look inside. If there is a screw in there you should be able to do this yourself. If there is no screw (sometimes torx/star head, sometimes flat/straight head) then yo uwill need to take it to a service agent/dealer as a special jig is needed to lock the spindle/chuck.
If there is a screw you need to remove it. It will be a left hand thread so turn it clockwise to remove. It will be proabbaly be tight as it will be thread locked in the factory. Once this is removed, clamp a 10mm allen key in the chuck adn steady the drill on a workbench. The actual chuck will be a normal thread so this is removed by turning it anti clockwise. It will take a sudden impact to start it off so put the gearbox in a low gear and turn the clutch to 'drill mode'. Holdong the machine steady you can hit the allen key sharply to start undoing the chuck. It may take several hits to get it going.
Jun 13, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
I have ratchet sound on the chuck all the time I'm tightening or loosening it. It comes from the CHUCK itself and when drill bit has been tightened, the ratched sound stops. So it does NOT come from the...
there is usually a m5 machine screw holding on the chuck... get the jaws open fully and get a ph2 down the middle... you'll feel it. the screw is counter threaded so turn clockwise to get it out... caution the machine screw will strip quite easily which is very boring... zzzz
so hold your drill somewhere steady and good luckm
rate if useful
Oct 29, 2009 | Panasonic EY6409GQKW 12 - Volt, 1/2"...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
172 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
