Question about Dell XPS M1530 Notebook
Error code 2000-0322
The diagnostic reveals an error code 2000-0322 : LCD inverter unable to modify brightness.
  • 46 Answers
The inverter is a small component behind the screen it regulates the display it is common that they fail regarding cost then you might be best looking on various sites for a comparison they are relatively easy to replace
Posted on Dec 14, 2012
2 Suggested Answers
Davethesnake
  • 689 Answers
SOURCE: hi i have dell inspiron 1525 my screen is almost
This is one of the worst sorts of failures darling.
Posted on Sep 06, 2010
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
Dell error code 0326
Error Code 0326 means LCD inverter error, unable to turn lamp ON/OFF.
  • Update to the latest BIOS.
  • Turn off your computer and reconnect your LCD cable.
  • Repeat the diagnostics by turning your laptop on and tapping F12 and selecting diagnostics
  • if you still get that error then it could be these parts LCD cable+LCD needs replaced
Jun 16, 2014 | Dell Inspiron 1525 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
I have a problem with my M140 Dell XPS LCD display. I have a white patch from top to bottom not complete screen but a portion of it. Do I have to replace LCD or inverter
This is most likely cased by your LCD screen being defective.
The inverter will either light the back light or not, it does not have the ability not to filter certain parts of the screen. It could however be that if your seeing wash out and it goes from super bright white to a dimmer bright white the inverter has failed and the bulb is running at full power.
Most likely it is your LCD.
To test your inverter, turn your computer off.
Press and HOLD the FN key while pressing the POWER key.
Once you see booting dell diagnostics, or something similar you can release the FN key. You might have to release the POWER key sooner if the under shuts down.
Oct 24, 2009 | Dell Inspiron XPS M140 Notebook
My Dell Inspirion6400 screen wont come on. I attached it to an external monitor, and it came up with the error code:0326 LCD Inverter Error, unable to turn lamp on. If I replace the LCD inverter, will...
Check out http://www.ccfldirect.com. they have a wide variety of inverters and backlight tubes for LCD panels and laptops. I'd change out the tubes at the same time you replace the inverter. The cost is minimal, and will increase the likelihood that you'll be successful
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Run Diagnostics I got Error code 0322, Message 2000-0322 LCD Inverter unable modify Brightness.
You need to replace the LCD inverter; it is the small board that the LCD monitor plugs into and the inverter plugs into the motherboard. Here's one for $10. Oh, and please take a moment to give this solution a fixya rating. Thanks! :c)
Jan 14, 2009 | Dell Inspiron 6400 Notebook
Error accessing the lcd inventer
The error code 2000-032 (LCD Inverter error, unable to turn lamp ON/OFF) sounds like your LCD screen has a problem and needs to be replaced. The inverter circuit is located on a small circuit board on the LCD display panel. You can try reseating the LCD connector and see if this helps. Here’s a link to the service manual: http://supportapj.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 26, 2008 | Dell Inspiron 6400 Notebook
Dell XPS M1530 Notebook Logo
666 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
