Question about Plumbing
Hi John, I have a goulds bgr75 pump which does not pump ! There is plenty of water for it to suck from just does not pump. The green light is on, on the control box tool. Is it stuffed ? As it has only done aprox 4 months of work. My email is pdplumbing@adam.com.au regards Paul
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I have a pump that will not pump higher that 40
The Goulds J5S pump is only rated for 40 psi. Is it possible that is the correct operating pressure? Did you get a higher reading in the past?
Posted on Dec 27, 2010
  • 512 Answers
SOURCE: Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Posted on Oct 07, 2012
Goulds j5s pump discharging rusty water and green moss particles. how do i flush
If its discharging all the time, I would say its sucking up contaminated water but if only occasionally, that would suggest something is rusting / deteriorating in the system and it "grows" when the pump is not in use. I would have a close look at the source tank(s), the connecting pipework and as a last resort, disconnect the pump and have a look inside the pump chamber.
Jan 04, 2016 | Goulds Pumps Goulds 1/2Hp Shallow Well Jet...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
The controler not have green light on
the voltaje is correct in controller 2ab2 but not light green on
Apr 17, 2014 | Goulds Pumps Goulds 2AB2 - AquaBoost II...
My goulds pump plus jet j5s comes on fine win u plug it in and its geting plenty of water just wont gain any pressure
It sounds like a leaking foot valve. Not sure but I have seen this many times on other pumps.
Nov 28, 2013 | Plumbing
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
My water pump when reaches 40psi clicks on and off contineously
Pull the pump and check for blockage holding the foot valve open allowing the pressure to leak past the impellor back in to the water table. Sand --rocks are sucked up during the pump operation and will hold the ball off the seat.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
Aug 22, 2012 | Plumbing
I have a pump that will not pump higher that 40 psi. There seems to have plenty of water to the inlet, it is even gravity flow no suction needed. This pump is about 9 years old and recently during a flood...
Dec 27, 2010 | Plumbing
Plumbing Logo
51 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
