Question about Estro Barista
How to descale estro vapore
3 Suggested Answers
  • 1089 Answers
SOURCE: my estro vapore has lost pressure. it will not
Hi Some of the old Estros had Cosmic pumps and that was one of their problems. You can switch out the old Cosmic for a Ulka pump. There would be some modifications but not much.
Posted on Feb 06, 2010
  • 1089 Answers
SOURCE: replacing a Cosmic pump with Ulka pump
Hi Check ebay.
Posted on Feb 07, 2010
Problem with espresso machine
make sure your coffee grind is not too fine. try a coarser grind. imagine two bucket, one with fine sand and one with gravel. the water will travel faster through the gravel. if this works then slowly make the grind finer until creme returns on your espresso. also try descaling the machine.
Jul 14, 2013 | Estro Barista Athena
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
ESTRO VAPORE / Thermostats verification ?
Using an ohms meter, disconnect one of the leads and check the reading across the terminals. Make sure power is off when checking resistance.
May 01, 2010 | Saeco VIA Venezia
My estro vapore has lost pressure. it will not force water through the filter. how or where can I fix?
Feb 06, 2010 | Estro Barista
ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
Aug 11, 2008 | Estro Barista Athena
Estro Profi - Green Light not coming on
It is vapor lock possibly,
1. Soak the steam wand in some hot water for a few minutes
2. Using a cup at the bottom run the brew function and open up the steamer valve until it starts pulling water through. May take a bit of time. Be careful with the steam.
Hope this helps
my white profi of 12 years has been acting up and will not even turn on.
Good luck
Aug 09, 2008 | Coffee Makers & Espresso Machines
Can't prime Starbucks Estro Vapore espresso machine
I can't get that screw off that holds the screen down. I'm trying to change the rubber gasket. The screw just goes round and round in both directions! I'm afraid to just pry it off!
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
59 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
