Question about HP DesignJet 1050c InkJet Printer
With IP printing through Novell iPrint the AutoCAD plots partial. What can we do to solve? Set to LPR or toe RAW printing?
    Genius:
  • 1,605 Answers
Usually RAW works.
if you the printer connected in any of the parallel port the LPR (DOS) line print shuld work.
Posted on Jan 12, 2009
How can i convert an AutoCad DWG File To PDF Format
1. Close AutoCAD.
2. Install a free PDF Reader that incudes a virtual PDF printer. (Like NitroPDF)
3. Make the Virtual PDF Printer your Windows Default Printer.
4. Start AutoCAD & Plot/Print to the Default Printer, just like you print to any other printer. During the printing process, you will be asked for a file name & location to save the 'Printed' PDF file.
Apr 16, 2014 | AutoCAD LT 2014 for PC
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
Network Printing is not working
what drivers are you using? try both PCL and UFRII. also, check thru WWW interface(will be faster) if there's a department managment turned on. i it is, disable it. i assume you are creating local tcp/ip port with printer ip, raw mode, port 9100 and device is canon network printer. also did you noticed is windows discovers the device as canon network printer, raw mode etc, or you have to enter it manually? if it can't discover it, there's some connection problem.
Jul 23, 2009 | Canon imageRUNNER 5000 Copier
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DEVICE STATUS OFFLINE
To solve this problem you'll need setup the printer up with LPR Protocol. Go to Devices and Printers. Right-click on the printer in question select Printer Properties. Go to the Ports tab. Find the port you've setup then click on Configure Port. In the block titled Port Name you'll need to enter the name of the Gigafast Print Server. It's normally 1P_PrintServ??????. The ?s are the last six entries of the print server's MAC address. Next, in the Printer Name or IP Address enter the assigned IP address, example (192.168.5.3). For the Protocol select LPR. LPR Settings: Queue Name: same as 1P_PrintServ??????. Lastly, check the box that says LPR Byte Counting Enabled. Now when you shutdown and restart the printer will remain online.
Apr 15, 2007 | GigaFast Ethernet EE171-PR Print Server
HP DesignJet 1050c InkJet Printer Logo
96 people viewed this question
Ben Johnson
