Mouse and keyboard do not respond after selecting the ASUS system recovery tool
SOURCE: dell dx520 usb mouse and keyboard freezing
Go this mention Site addres & download the drivers http://supportapj.dell.com/support/downloads/ ........................Sameeraryan
SOURCE: Mouse and Keyboard wont work after booting system?
First thing I would try is System Restore.
Start
Programs
Accessories
System Tools
System Restore
And go back to a date before this morning. This should take care of your problem most of the time.
Now when you say the monitor was black... do you mean because of the screen saver/power settings turned it black? Or did it go out on its own? If on its own, sounds like it might be overheating. See if it works once cold.
SOURCE: After disconnecting Mouse and reconnecting it no
If you are connecting PS2 mouse to the computer your pc willl hang up.
i f you are connecting USB mouse and it not running longer there may be a problem in mouse wire . The wire cut can create these problem
SOURCE: I'm seeking to reset my
Just borrow an Windows 7 install disk and reinstall with it and the key on the sticker. Later you will have to add the sound drivers, either directly from Realtek or thru the Windows Update.
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
