Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
After cycle,about 2 " of water stays in the unit and will not
Drain How to fix?
Possible that the drain or the disposal is clogged. If drain is open check drain pump.
Posted on Jan 13, 2009
4 Suggested Answers
  • 90 Answers
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Posted on Jan 05, 2008
wheelshot
  • 102 Answers
SOURCE: New Quiet Partner 2 doesn't drain at end of cycle.. how to fix?
May be that there was a little regular soap or something put in that made it suds up causing it not to drain. Vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Posted on Apr 11, 2009
  • 10 Answers
SOURCE: E5 comes up when running wash cycle
in this case e5 means too much water in the machine when it is supposed to rinse.
these machines have either a solenoid opperated drain valve or a drain pump.
could be a kinked or pluged drain hose. check this by removing the drain hose (probably red) from the drain it attaches to (probably under a sink)
put the hose in the sink or bucket and wait for it to drain, drain should be fairly powerful (hold the hose and be careful the water is hot)
if the hose is not kinked and little or no water comes out you have likley have an obstructed drain valve or a broken pump or solenoid.
at this point i would call in the pros, or you can try to fix it yourself then curse and wish you had called the pros.
good luck
Posted on Aug 21, 2009
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
I have a whirlpool quiet partner 2. During a cycle, anyone of them, the water drains while the arms are spinning. Then it just runs dry. Does anyone know what the problem is or how it can be fixed?
The Triac/SCR in the control module is probably U/S and staying on which keeps the drain pump on while the unit tries to perform normally.
Dec 06, 2012 | Dishwashers
My whirl pool duet sport keeps having an error message of f21 and 5d. i read that it means the water is not draining right. what can i do to fix this?
F21 means to a long drain.
Basically means that water is not pumping out quick enough. If all the drain lines have been checked for blockages and restrictions the manufacturer recommends the pump is replaced. Some times the impeller can become damaged or the motor which can cause the pump to work slower then it should causing this error code. If you took off the hose from the tub to the pump and found nothing then I doubt there is a blockage in the drum (it would have moved into the drain filter).
Sd or 5d error SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Hope this helps.
Aug 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
The water stays in the bottom of the dishwasher .
The drain pump is not working fully to discharge off all the water in the drain cycle. You must check the drain outlet for any blocks in the drain valve/pump. open and clean the unit. If ther pump is not effficiently pumping out in the ddrain cycle then the unit must be changed or serviced.
Oct 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The machine will fill with water and run through the first part of the cycle, then stop. If I turn the setting dial to the next setting the machine will start, but does not pump out the water. At each step...
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
Nov 16, 2009 | Equator EZ 3600 CEE Front Load Washer /...
good luck
Aug 19, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
It doesn't drain completely
if ur unit is connected to an air gap,which is mounted rhs rear corner of ur kitchen sink,remove the air gap cover and look for any food debris stuck there.debris will restrict the free flow of water during and machine has fixed 2 min drain cycle. so some water can remain the unit after drain cycle is over.
Aug 17, 2009 | Maytag MDB3100 Dishwasher
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Feb 22, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
50 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
