Can't find menu button on remote control for GE6833 TV
jerryg50
  • 1689 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
SOURCE: Input button
I cant gey my playsrarion to work through my audio input. Please email me a answer on how to fix this problem. Thanks for your time
Posted on Aug 17, 2008
  • 33 Answers
SOURCE: lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Posted on Apr 28, 2009
  • 8457 Answers
SOURCE: remote control
Buy a original remote.Website 1-800-Remotes factory original.Get the original remote.
Posted on Dec 18, 2009
  • 290 Answers
SOURCE: connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Posted on Jan 02, 2010
Locked rca tv and don't have remote
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 14, 2012 | RCA Televison & Video
RCA LCD TV locked up.
Aug 12, 2012 | RCA RCR312W Remote Control
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
Can't get closed captioning to go away,,, can't find it on the menue does anyone know how
Check whether there is a "CC" button on the remote control. If you are using a universal remote control, it might not have this button. As there is no selection for closed caption in the TV menu options, its original remote control will have this CC button. If you are the original remote, press this button once.
Jun 08, 2012 | Norcent Technologies2703 27" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Can I pull menu up on Trutech T2000FT without the remote?
Hello
If there isn't a button marked 'Menu' at the front panel of your TV, you can;t pull out Menu option without its remote control. No TV, which haven't Menu Button on its front panel, can't be controlled for all of its functions without its remote control OK.
Feb 13, 2012 | TruTech T2000FT TV
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
Have a model # G35830WK that is in parental control how do we get it off
Hello
You should have its original remote control to unlock this set. If you ahven't one, just try to get it from any of your friends or relateives, who owns the same type of set. After unlock, you can use any other universal remote control. To unlock it:
**If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
Jul 08, 2011 | RCA Televison & Video
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
