Question about Magellan Maestro 4250 GPS
The Device does not say if it is charging
When I plug my device in there is no lights sounds or indications that the device is indeed charging. My question is do i have to leave it plugged in for a while then it will automaticly boot up or is there something wrong with this particular device?
  • Anonymous Mar 26, 2009
    need instruction on how to charge the battery on my magellan maestro 4250
I have the Magellan 4250 and was also confused by this at first. However, you can see the unit charging. If you plug in the wall charger, turn on the unit and go to the User Options menu and select System Settings. You will see a green power indicator at the bottom of the page under the button options. When you are charging the unit, this will be pulsing. Once the unit is fully charged the green line will be solid and unmoving. It takes a long time to charge so you may have to be patient. I turn off the gps while it is sitting on this menu page and when you turn it back on you will be on the page and it is easy to see if the charging has completed.
There are no sounds or indications unless you go to this menu page. It does seem strange.
Posted on Apr 13, 2009
I felt the same way until I found the Pattry charging icon in the "system settings menue. Go to User Options and then choose the System settings. At the botto the menue is a battery icon with a number of boxes. If it is charging the boxes illuminat in a sequence. If it is un pluged the icon shows , by number of "boxes" the strength of the charge.
best Brooks
Posted on Jan 15, 2009
  • 47 Answers
It usually needs to be left for a while until it start recharging, a few minutes or so. If this does not solve anything then it would be best for You to bring it back for servicing.
Posted on Jan 12, 2009
How do i fix a rand McNally tdk 500 gps that won't turn on
Have you plugged the device in using the wall and\or vehicle charger? When plugged in does the charge indicator light come on? If the charge light does not come on the then device is not getting power. The USB port could have malfunctioned but it can be repaired.
If the charge light is coming on then the device should power on using the power button or by resetting it using the reset button on the back of the device.
My suggestion is to call Rand McNally technical support. An engineer can perform a more in depth diagnostics and provide a solution.
Dec 23, 2014 | Rand Mcnally TND 500 Car GPS Receiver
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
How long should i charge it
I have this same panel.
You may indeed plug the panel into the computer, and plug your USB powered device into the panel without issue. This will charge both the panel battery and the device at the same time.
Aug 31, 2012 | Opteka BP-SC4000 Solar Charger
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Battery will not fully or will not charge
Whenever you first purchase a device you must charge the phone fully otherwise if you charge it partially an then use it it will never charge good. You may need new battery see if youe warranty covers it \. If you are within 30 days of purchase you can exchange it at no cost!
Sep 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Magellan Maestro 4250 GPS Logo
170 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
