Question about Soleus Ph5-13r-35d Portable Air Conditioner
I have a soleus ph5-13-r-35d that has an error code e-4
When the unit runs more than 30 minutes i get an error code e4
5 Suggested Answers
  • 9 Answers
SOURCE: Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
Posted on Mar 12, 2009
  • 57 Answers
SOURCE: I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Posted on Jul 16, 2010
guru_fixya
  • 944 Answers
SOURCE: On soleus ky-32u air conditioner,
The water tank is full the solution is to Empty the water tank.
The water tank is not installed correctly.Just install it correctly.Completely re-insert the water tank again
See page no 14 in the manual.
click here to download the manual.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
hvac1960
  • 2133 Answers
SOURCE: e4 error after about 30
E-4 Short of gas. Check for leak and rectify.
Posted on Jan 15, 2011
My portable goldstar airconditioner is showing E4 .What does this mean
E4 is a Display panel communication error.
Might have been something as simple as a Power Surge.
Power unit off for 30 minutes and then restart.
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Goldstar Heating & Cooling
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
How to fix E4 error
check the water tank flipper if broke it will directly cause the unit to not function and the E4 message will apper on the display screen.
May 26, 2014 | Soleus LX-140 Portable Air Conditioner
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
My Soleus Air HM2-15R-32 displays an E4 LED when turned on. How do I reset the code.
try unplugging it from the wall for 15 seconds and then plug it back in.this normally works for me.if it doesn't work then let me knoe
Jan 23, 2013 | Office Equipment & Supplies
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Error code 4
check the sub code , it would read E4-? , such as E4-10 is fuser fan, E4-01 is low fuser temp, sometimes hold the print key after in code and sub code may appear. Then you can go to next step of repair.
Jan 30, 2008 | Panasonic FP-7735 Black and White Copier
E4 error being displayed
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
Soleus Ph5-13r-35d Portable Air Conditioner Logo
95 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
