Question about Tasco Sonoma Binoculars
Double vision at zoom 12 and above I get a double immage
Double immage pentax 80x40 binoculars
alignment of pentaprism, you need to send it in or if its a goner, try it yourself. Unscrew one of the objective barrels and observe the pentaprism mounts. They may be in screw driven supports. adjust screw one at a time to see if you can get it back into alignment.
Dec 11, 2012 | Pentax Optics
The image is blurry (ghosting) and dark.
the tab bonds on the lcd panel where they attach to the Drive circuits above the TCON samsung is famous for bad flex tab bonds. Does the screen appear llike its in slow motion and double immages in that half of the screen as well as appear to have dark bands aross the screen? If so its probably the flex tab bonds.
Mar 30, 2012 | Samsung LN40A630 40 in. LCD TV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
The immages have vertical lines
i have problem s500 camera zoom is not working.
Jan 27, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
Apr 06, 2009 | Tasco Sonoma 16-840WA-1 (8x40MM) Binocular
Double Vision
Your glasses have had a hard drop or jar- they are out of colluminatiom send them to Deusch Optics in Nevada
Jul 31, 2008 | Oberwerk (OBERWERK1030X60ZOOM) Binocular
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Mar 01, 2008 | Sony KP-61S65 61" Rear Projection...
Hdtv projection monitor (pt-53w-42h panasonic
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 21, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Tasco Sonoma Binoculars Logo
27 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
