Question about Sky I Blade Mini IR Helicopter W/ Remote Control
Troubleshooting the wireless us eagle copter - Sky I Blade Mini IR Helicopter W/ Remote Control
The green light won't turn on when I try to charge it on the controller. It also won't charger at all, just the red light on and copter off
Posted on Dec 11, 2015
  • Bud Dease
    Bud Dease Dec 11, 2015
    It's a us eagle small one that was $20. It hasn't worked since I opened the box
My remote control isn't syncing with the copter
Go to twit.tv
look for Select :All Shows:
Click on the show called "Know How....
They have many free courses in "Remote Copters"
May 03, 2015 | Brookstone U-Control Combat Copter with...
Air Hogs R/C pocket-copter not functioning
your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
May 02, 2015 | Spin Master 1001130 Air Hogs R/C Pocket...
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Nemisis battle copters on same channel
I just fixed this problem on mine. The helicopters are not actually set on channel A. Not sure why it says that on the bottom. They match the channel on the controller.
Here is how:
-First turn one helicopter on
-On one of the controllers select channel "C"
-Move the throttle stick(on left) all the way down
-Turn the controller on
-Move the throttle stick all the way up and then back down again
-When the light goes from blinking green to solid green that copter is ready
-Repeat this with the other copter but select channel "B" or "A" instead
For some reason it works better when you start with the higher channel, C, first and then work your way down.
Hope this helps!
Jan 08, 2013 | Toys
Hello Fixya experts, I'm having a SYMA 9077 Double Horse Eagle. The problem is it doesn't lift off but just spins on the ground. The bottom blades are CCW, the top ones are CW. Plz help me analyze this...
The problem may be due to broken blades or untrimmed. Change the blades with new one is the first option if the same is all right trim your copter through trimmer button on remote. sometime copter not fully charged and this problem occurs.
Jan 05, 2011 | SYMA Toys industrial 9077 Double Horse...
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
Hamilton X-Copter Watch troubleshooting
Just pull it out to the second click/position and adjust time. When you unscrew the crown, it is in winding position, when you pull it out to the first click - it is in day/date adjusting position, when you pull it further out to the second click - it is in time setting position. In case if you do not have screw down crown, everything is the same, just you do not have to unscrew the crown. Rate me, plz.
Jan 27, 2010 | Hamilton Watches
Sky I Blade Mini IR Helicopter W/ Remote Control Logo
663 people viewed this question
Top Sky Toys Experts
NOEL
NOEL
matt
matt
Are you a Sky Toy Expert? Answer questions, earn points and help others
