Question about Sony Handycam CCD-TRV68 Camcorder
No picture when i turn the cammera on - Sony Handycam CCD-TRV68 Camcorder
Lost my plug in for the kodak easyshare c330 where can I get one to plug into camera and computer
If you want to download the pictures and movies from the cammera you can unload the memory card from the cammera and insert it in a card reader and then to the usb and without a cord you can do this easily, but you will get the cord in a cammera shop. available in your locality.
Sep 09, 2010 | Cameras
The flash won't work under any setting I find.
Try changing it to single picture mode, if cammera is in burst mode the falsh is forced off.
Apr 29, 2010 | Sony Cybershot DSC-T200 Digital Camera
A friend bought a nec cammera on our holiday and
Need more info...where were they downloaded to?...a folder, my pictures, or a software program?
Feb 11, 2010 | Cameras
When I turn on my cammera it says to instert the memory stick when the memory stick is already in.
Hi friend,
Your memory card has been damage...you should check in another cammera.
With Regards
Dec 30, 2009 | Kingston 1GB Secure Digital Memory Card
Its unable to take pictures
it a problm with ur cammera, so kindly proply install ur cammera driver.
Nov 17, 2009 | ASUS Eee PC 1000HA Notebook
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Can't transfer pictures to pc.
you can download the drivers of your cammera on the internet and install them...
try in google or in the website of the cammera´s brand.. there you could find the drivers..
if you still have problems i could help you finding them..
cheers
Mar 24, 2008 | Samsung L73 Digital Camera
Fuji finepix A120
are you using rechargable batterys or weak batterys. my fuji won't work unless I use a e^2 titanium batterys. they have lots of jam (3500's?). anyways when the picture or ccd goes to charge there isn't enough juice to fire and the cammera dies. or maybe there is junk on the connections and won't let enough volts through. rechargeables are bad becouse they don't have the volt output needed - 1.2v charged I beleive. the other batterys are expensive but they've been in my cammera for three months, or about 300 pictures.
hope that helps :)
Feb 01, 2008 | Fuji FinePix A120 Digital Camera
Casio ex-z700
Your lens has sustained damage and needs to be sent in to repairs.
Jan 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Can't Take Pictures
my friend had the same problem with his kodak camera, the problem was that the aperture refuses the open. his solution was accidental, not sure if it will work on yours. he released the battery for a while, then after a day or two, he puts them back in, and the aperture opens up. try it
Sep 13, 2005 | Kodak EasyShare DX4900 Zoom Digital Camera
Sony Handycam CCD-TRV68 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
