Question about Sewing Machines
Threading a Brother serger model 929 D
How to thread manual
  • Sewing Machines Master
  • 7,365 Answers
Here's a free manual, see if it's the right one for the machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_929D_ENES_1133.PDF
Posted on Dec 10, 2012
  • 4 Answers
SOURCE: TS 380 Tiny Singer Serger Manual - Threading
If you go to this page: http://www.singerco.com/accessories/manuals.html
at the search box, type in just the model number, ts380, and click search.
at the results screen you'll the "Free Download" for this manual (PDF format). (there are also options on that page to have them mail you one; but luckily this is one which also has a free downloadable version!)
Enjoy serging!
Posted on Sep 11, 2008
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Posted on Oct 20, 2008
  • 136 Answers
SOURCE: Janome Mylock 534D serger thread 4 (green guides) breaking
what issue?
Posted on Jul 07, 2009
SOURCE: I lost the manual to my Brother Homelock 920D
i need information on threading a 920D brothers serger, on paper so i can take it to my machine to thread
Posted on Aug 31, 2009
Zenqi
  • 208 Answers
SOURCE: problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Posted on Jan 16, 2010
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
My needles hit and seperate on top loop when I try to use my Brother 925D serger. What can I do to fix this?
Make sure that you thread your machine in the exact sequence your manual tells you to, and that when you thread your machine, it is powered off, and the presser foot is up. If, you have a hard time seeing your manual, go to www.brother-usa.com support and then choose home sewing and embroidery, and then select your model # 925d and download your free manual. I have the 1034d and did not thread the upper looper first (3rd from the left) and it caused me grief. Now, I remember to follow the instructions exactly. Seems that the thread will loop around the lower looper if you don't do it right. Try this and if that does not work call Brother at 1-877-276-8437 and ask them.
Apr 16, 2011 | Brother 925D Serger
How to thread a serger model 934d made from brother it has 4 thread to do
You can look at youtube.com and see various sergers being threaded, also Brother at www.brother-usa.com, and www.singerco.com is quite helpful for threading a serger. All sergers pretty much thread the same way, remember always thread the 2nd from the right first. You can download your manual for free at the Brother site and enlarge the diagrams. Just take your time, it took me almost an hour to finally get it , now I can thread any machine without any problems. At first, I was very intimidated, but you will get it, really.
Mar 20, 2011 | Sewing Machines
Hi i just got a new brother 1034D serger. And I'm
I found that I had to remove the stitch finger to thread the machine properly. Do remember to re-install it before starting to sew. If you are using 3-threads only, then remove and store the stitch finger.
Puzzled that this instruction is not in the threading section of the manual.
Jun 23, 2010 | Brother Lay-In Thread Serger Mechanical...
I have no manuel and need to see more detail threading instructions,
Take this link to Brother website and enter your model number to get a printable manual.
http://www.brother-usa.com/Manuals/
Nov 03, 2009 | Brother Lay-In Thread Serger Mechanical...
I lost the manual to my Brother Homelock 920D serger. I want to know how to thread and use it.
Mar 04, 2009 | Brother Lay-In Thread Serger Mechanical...
Brother serger
You can go to www.brother-usa.com. I just was in there and you follow the prompts with your model number etc.. good luck....
Aug 11, 2008 | Brother Lay-In Thread Serger Mechanical...
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
