The car is a 06 tiburon gt. When i shift from park or reverse into drive it starts and wont shift out of 3rd gear. so the obd says its a shift solenoid c that needs to be replaced. Prior to the code coming up it said that the speed sensor was bad so i replace that. any suggestions or info to help me. Please and thank you.
SOURCE: 02 Neon won't shift out of second gear in Drive
Sounds like the valve body is loose, warped or blown
SOURCE: Transmission wont shift into 3rd gear.
I had this exact problem on my 2005 5.3L Suburban... It would shift into 1 and 2 and reverse, but not 3 and 4.
I took it into a transmission shop, and he said the 3-4 shift solenoid was burned up. Wanted 1500 to fix it. Far from home, so I have to pay it.
SOURCE: TRANSMISSION 2nd to 3rd GEAR HARDSHIFT
SOURCE: E40d trans will not shift into 3rd or 4th gear, only rev. 1+2
check or replace your thottle position sensor tps that trans needs to know where the throttle is to shift if it is bad it will do as you say wont shift to third
another telltale is it will act like it goes into lockup when shifting into reverse and stall the engine
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will
Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
gear?
Buick Park Avenue: Transmission will Not
shift into drive?
No
is turned ON?
Issue?
mornings?
driving?
Park Mode?
These will help.
Thanks.
