Question about Yamaha 2400is Portable Generator 2400 Watt Inverter 3 Year Warranty
Surging 2400 generator on idle
Surges when on idle
    Problem Solver:
  • 5 Answers
Did you ever fix the problem?
Posted on Nov 28, 2014
1999 6.8 v-10 surges at idle fault code po122 throttle control sensor bad. Will a new sensor fix this surging
Mills, a new sensor will definitely fix the surges at idle...
Best regards,
Bill
Oct 25, 2014 | Cars & Trucks
Surging idle
Bad throttle position sensor.
Nov 24, 2013 | GMC Yukon Cars & Trucks
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
Have a 94 astro 4.3 new gaskets block up. surges at idle no engine light. runs fine at all other speeds
Honda's among other vehicles are prone to having this surging problem. I learned a little trick that takes about 5 minutes to do and it has never failed to solve the problem. Take a 1/8 inch drill bit and just below the center of the butterfly on your throttle body, drill one small hole. The vehicle idle surges because the throttle body assembly is not getting enough air through it at idle. This will stop the surging. You only need the 1 hole drilled. Don't forget to stuff a rag or paper towel in behind the butterfly before you drill the hole. It will prevent metal shavings from entering your motor. (do this with the motor not running)
Nov 26, 2012 | Cars & Trucks
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Yamaha 2400is Portable Generator 2400 Watt Inverter 3 Year Warranty Logo
206 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
