Televison & Video Logo
fernando hernandez Posted on Dec 09, 2012
How to remove icons from screen? - Televison & Video
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Dec 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
6304
Points
54
Its on store demo mode, go through menu with remote, and look at options on menu to change from demo mode
How to remove the icons on the JVC digital camera GZ MG 37 AH
To remove icons from the display screen on your JVC digital camera model GZ MG 37 AH, you will need to follow the specific instructions for your camera model. Here are the general steps you can follow to hide or remove icons from the display screen:
  1. Press the Menu button on your camera to access the main menu.
  2. Use the arrow buttons to navigate to the "Display" or "Setup" menu.
  3. Locate the option for hiding or removing icons from the display screen. This option may be called "Icon Display," "Screen Display," or something similar.
  4. Use the arrow buttons to select the option for hiding or removing icons, and then press the OK button to confirm your selection.
  5. Use the arrow buttons to navigate through the available options for hiding or removing icons. You may have the option to hide all icons, hide selected icons, or show all icons.
  6. Select the option that best meets your needs and press the OK button to confirm your selection.
  7. Press the Menu button to exit the menu and return to the normal display screen.
Unock a zte google account lock
Add
From any Home screen, tap the All apps icon.
Tap Email .
If no accounts are configured:
Enter the username and password.
Tap Next .
Follow the on-screen instructions.
If other accounts are configured:
Tap the Menu icon.
Tap Settings .
Tap Add an account .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Under Accounts , tap the account type that you want to remove (for example, Google).
Tap the name of the account you want to remove.
Tap the Menu icon.
Tap Remove account .
Tap Remove account to confirm.
if you not get any solution please go the :-https://support.t-mobile.com/docs/DOC-27449 and ask your query
Note:-Need the ZTE network unlock code just get in one click only
Official Zte IMEI Permanent Unlock Important Select the Current Network...
https://www.unlockninja.com/unlock-zte+phone
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Tap the Menu icon.
How to remove an icon from home screen
On most Android tablets, you simply press and hold the icon until the screen changes modes (to arrange). Then you should see an option to delete/remove at the top of the screen. Just drag the icon to the top of the screen and it should leave the home screen.
How do I rearrange/remove apps from the home screen on a Bauhn Sphere 5?
Hi Ess Kay
I am not sure about your phone brand and model; however, if it is an Android Phone, everything on the screen can be shifted around, removed or place new icons on the screen.
All you need to do is tap on an icon and hold it for a while. It will change colour and depending on your phone and settings, a short vibration. You can now drag it to where you want and drop it there. You can also move icons from one page to another by dragging it to the edge and hover around there - the screen will slide to the next page. you can drop the icon in the new page.
To remove, once you select an icon, e red bar, remove, of similar indicator will appear on the top part of your screen. drag the icon there and drop it.
hope this helps.
I have multiple icons on my android and I don't know how to remove them
Removal could vary depending on the phone you are using and the version of android you have, and which screen the icons are on.
If the icons have been added to the home screen, on my S4 just press and hold the icon that you want to remove (just a couple of seconds), then drag the icon to the bin at the top of the screen.
If you want to prevent icons being added to the home screen when you install new apps, goto the google play store on your phone, and click on 'Play Store' at the top of the screen. Then goto 'Settings' and untick 'Add icon to Home screen'. Any new installs will be in you applications folder but will not be added to the home screen.
Jun 08, 2014 • Cell Phones
1helpful
I have a Apple IPad 2. I want to remove a home screen Icon, how do I do this?
press and hold down the icon until you see it shaking and an x next to it then press the x and delete.
3helpful
Icons on the home page
Tap the white-on-blue up-arrow near the lower-left corer of the screen, then drag the unwanted icons to the icon bar at the bottom of the screen. When done, tap the white-on-blue down-arrow at the upper-left corner.
Bear in mind that not all icons can be removed from the home screen.
A icon just appeared on my screen that says phones
You may have accidently put an app icon to home scree. You can delete it by press and holding the icon. A trash icon will appear at the buttom of the screen. Drag the icon to the rash icon and you are done.
It wont delete anything. It will just remove the icon from home screen.
Also, to add any other icon on the home screen, go to menu, press and hold the desired app icon and it will be on the home screen.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
