Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
I pulled the front off of the dryer. Underneath was completely covered in lint. I used an air compressor to blow out the lint and then vacuumed. I started the dryer to observe and noticed that it would light initially for a couple minutes. After that I would see a glow as if it was attempting to ignite but at never ignite. Any idea what the problem could be?
    Top Expert:
  • Whirlpool Master
  • 42,943 Answers
The igniter was damaged. It needs to be replaced, even though it glows
Posted on Dec 09, 2012
  • G. Fig Dec 11, 2012
    So I took the igniter out and took it to a local Home Appliance store to get a replacement. When I took it in the guy tested the continuity. He told me it was not in need of replacement. I described the issue I was having and he recommended I replace the coils. I purchased them from him, brought them home to install and the dryer has been working perfectly all day.
SOURCE: gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Posted on Aug 27, 2008
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
SOURCE: Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Posted on Jan 06, 2008
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
Posted on May 14, 2009
Dryer is overheating.
Hi Renee:
Dryers are notorious for creating lint, and the lint can clog the exhaust hose.
I'd recommend pulling the unit away from the wall so that you can get access to the hose. Disconnect it and use a vacuum cleaner to get as much lint as possible out of the dryer and the hose.
Check the end of the hose where it dumps into open air. Sometimes trim with a screen was installed. these will plug up and no air can get out. Nasty safety hazard.
After you've got it as clean as possible, before you re-connect it, try turning it on ans see if it blows a bunch more lint out, an more importantly, that it blows lots of air.
Then re-connect the hose and try again, making sure that lots of air is coming out of the outside exit.
Hopefully you'll have it fixed.
Cheerfuls
Oct 14, 2015 | Maytag Dryers
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
Bought USED amana dryer dle330raw owner says works good but..... i ran it & it has to be set twice to dry anything! sandy
The problem could be in a few different places. Make sure that your dryer vent is not obstructed with lint or any other material. If it's clean then the problem is most likely in your air duct assembly. to clean this out do the following. Unplug the dryer. Pull the lower access panel off of the front of the dryer ( 2 screws ). Then remove the 2 bottom screws that are holding the front panel. Then remove the bulkhead ( 4 screws ). Be mindful that it supports the front part of the drum, and the drum might drop a little bit while you remove the bulkhead. Remove lint filter. Find a large compressor and blow out the air duct assembly. There will be lots of lint in there. Reassemble.
Feb 22, 2011 | Amana DLE330RAW Electric Dryer
I washed, then dried a rug that instructs to "air dry." (Now I see the instructions for proper care...) I have A LOT of little rubbery pieces in the dryer and I have a fear of setting the dryer on fire...
even tho you've cleaned out the lint trap and the drum, small pieces of your rug have most likely passed by the filter, or thru the seam where the drum meets the front and rear panels. I would recommend pulling off the front cover, and vacuuming out the "innards" of your dryer. That way you can be confident that you're good to go. You can also remove the lint filter and with a vacuum edging tool **** out any visible "chunks" in the duct. Let me know if you need assistance opening up your dryer.
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer shutsdown during cycle. Replaced high temp thermostat and heater coil. Did not fix
your dryer may have a drive motor problem. its probably plugged with lint. you can try to vacuum out the lint from inside the motor, but it would be better to take an air compressor or the vacuum blowing to get all the lint out.
if the motor gets overheated, it will shut itself off until it cools off.
Mar 14, 2010 | Maytag Neptune MDE4000 Electric Dryer
Whirlpool LGB6400LW suddenly takes multiple cycles to dry clothes. It used to do a great job...now it still gets kind of hot but takes 2-3 runs to get the clothes dry. It's 6 years old. Help! Thanks!
Try vacuuming out the exhaust vent hose and as much of the interior air passages as possible. Soak the lint screen in hot water and detergent to remove fabric softener deposits from the screen. Vacuum the burner intake and exhaust vents as well. Hope this helps!
Feb 08, 2010 | Whirlpool LGB6300 Gas Dryer
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
