Question about Mossberg Optics
How to disassemble Mossberg M4D rifle scope - Mossberg Optics
  • 8 Answers
SOURCE: RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
  • 2418 Answers
SOURCE: rifle scope will not track with the adjustments
When you make your adjustment tap on the scope with a small screw driver handle a few times before you fire her. Work slow and tap as you go.
Posted on Jun 28, 2009
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
  • 12 Answers
SOURCE: how to zero Bushnell 3-9x40 scope rifle
http://www.bushnell.com/products/scopes/riflescopes/doa-riflescopes/
Go to this link & you will be able to zero it. If you lower the angle of telescope you will be targetting farther. vice versa. aqeelhafeez@hotmail.com
Posted on Mar 26, 2010
agent91
  • 2100 Answers
SOURCE: How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Posted on May 04, 2010
Where can I find a parts list for a marlin model 60 22 calibur rifle
not sure for parts list but the manual is located here http://www.marlinfirearms.com/customersupport/manuals.asp if its a specific part your after try ringing them on U.S. 800-544-8892 they should be able to point you in the right direction
Mar 27, 2015 | Mossberg Marlin Rifle 992m,989,mossberg...
What do I need to mount a scope on a Mossberg bolt action rifle
You'll need scope mounts to fit that MODEL of Mossberg rifle and a set of rings that attaches the scope to the mounts.
Feb 18, 2015 | Mossberg Optics
When i change to my mossberg 535 rifled barrel can i use the scope mount as open sights
I'm guessing it's a cantilever barrel? Mount is part of the barrel? Sticks back over the receiver? If it's not, then it should already have rifle sights. If it's a cantilever, why not mount a scope as it's designed? You can go 2 or 4 power fixed and you'll have no probs. The prob with using the mount as a sight is there is no front sight....and irons require a front and back to line up the shot. Having a back but no front, you have no sight radius.
Nov 09, 2012 | Mossberg Optics
How do I disassemble the bolt on a mossberg 100 ATR
Apparently the three previous folks have no idea that a Mossbergt 100 ATR is a RIFLE not a shotgun. Regretfully it is a press fit at the rear (multiple splines, pressure fitted into multiple recesses). What that means in English is that it's a factory fix. Sorry!
Apr 11, 2012 | Mossberg Optics
I have a mossberg mod 352 KB with a broken firing pin need a schematic of the rifle or the firing pin, any help would be appreciated. Thanks
Go to gunparts.com online, they have schematics for every gun ever made and parts to boot. They sell to the public, certain items of course. Check them out.
May 29, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a mossberg mod. 500 slug gun. what do you recomend for slugs ?
Is your barrel a smoothbore or rifled? If rifled, you'll get better accuracy with one of the sabot type slugs. Otherwise, shoot what your gun is most accurate with.
Oct 09, 2009 | Mossberg Optics
How do you reasembal the trigger assembly of a mossberg 500 i am haveing problem with the spring positioning
look on the internet you will find a blow up picture of the mossberg 500 in this list of guns
type in shotgun schematics
Sep 25, 2009 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a mossberg 152 semiauto dissambled and am having trouble getting it back together.Is their somewhere I can download or print a diagram on line? thank you.
If You still need it maybe I can take pictures of Mine to send You. I havent got all My pieces yet but maybe I have enough to help You get Yours together.
Apr 06, 2009 | Mossberg Marlin Rifle 992m,989,mossberg...
Optics Logo
332 people viewed this question
Top Mossberg Optics Experts
obsteiner
Ted Maxwell
ray gallant
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
