Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Samsung smart wash B1245S SE error
Does anyone knows what does the SE error mean?
washing doesn't work and water does not drain out from it at all...
I've lost the user manual and not sure what could be the problem?
any one can help
many thanks
Gosia
  • Anonymous Feb 01, 2009
    i have the same problem
You need to drain the washing machine by removing the little door below the drum door and pll out the the hose with a white knob (beware alot of water comes out so have a couple of pans ready. the fault means that there may be a blockage in the debris filter (next to the outlet hose yuo just pulled out) am sure you have prob already discovered the fix by now though!
Posted on Apr 28, 2009
  • jasontratts May 25, 2014
    tilt the machine back and wedge it up this will limit the amount of drain out liquid.. the flexible drain nozzle will probably be blocked.. take the plastic drawer cover off and then you can get a pan underneath as you gradually loosen the black filter cap. it might be abit stiff or you may have a coin trapping the rotation keep jiggling it ..it will probably come then when loose you may need to prize it with a knife .. but dont put too much pressure on .. once out, clean it out and check the impellar is rotating and perhaps use some limescale remover to get rid of some of the crud.. reassemble.. hey presto!!
Tilt machine back and wedge it.. this limits the drain out material.. open the cover below the drum.. the drain out nozzle will probably be blocked so forget it!.. remove the hinged cover and place a pan underneath.. slowly unscrew the black filter cap. it might be jammed with a coin .. give it a jiggle!! it will come.. you might need a knife at the end to gently prize it out. clean out the crud.. check the impellar is turning.. you might wish to use a bit of limescale remover to clean it out and then reassemble ... hey presto.
Posted on May 25, 2014
Samsung front loader washer has SE error
SE is spin error, it means that either there is something stuck in the pump or the hose between the drum and the pump of or the pump and the drain are blocked.
Alternatively it could also mean a faulty pump if there is nothing stuck in any of these places.
May 05, 2017 | Samsung Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Dec 17, 2010 | Samsung Washing Machines
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
The quick wash is stopping at 19 minutes and the letters SE are flashing
SE/5E usually means blocked pump or unable to drain water out in allotted time
Mar 20, 2010 | Samsung Washing Machines
Samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
I have a samsung B1245S washing machine error 53
5E - WATER DRAIN ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2009 | Washing Machines
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
My samsung smart wash b1245S 6kg washes but won't spin, it displays an EU message on digital display, what is wrong ???
its your drain pump
must be a common problem on this machine. i have had to change the pump 4 times now in the 4 years i have had it.
they are about £8 off ebay including the postage
Apr 14, 2008 | Washing Machines
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
3,130 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
