Question about GPS
Charging a Gramin 255W
I have a Grarmin 255W how do I know it is charging when I have it plug in  the car. It keeps telling me that the battery is low.
  • 4 Answers
BAD cable or the cig. lighter plug is not making contact, The tip of the cable that plugs into the GPS can be tested, but by someone that has the experience to do so, Need to know which is the output pins, very small and hard to test !!!
Posted on Jan 13, 2009
I just purchased a germin nuvi 255w gps, at wallmart, they didnt tell me how to or that i have to charge it. i am in rural area and one hour from walmart. i have a charger for my hearing aids it looks like...
hi jadister
you should of got a car charger and a usb cable with your 255W...you can use the usb cable to plug in to your unit and the other end in to your computer USB port...let it plugged in for a few hours to charge it good.
bill
Nov 27, 2010 | Garmin GPS
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
When i plug my gps in. it goes to the front screen were it tells me not use it while driving or whatever, and then it freezes and wont let me press anything.
if your plugging it in to your computer via the usb cable, its suppose to do that..you cant operate it while connected to the pc, thats for charging and data transfer only...
if its happening while plugged in to your home or car adapter, the adapter is either faulty or not the right one for the 255w.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 08, 2010 | Garmin nuvi 255W GPS Receiver
Automatically turning off after warning message
normally it's a sign that your battery is shot, should never leave them plugged into the car when not in use
May 14, 2010 | Garmin nuvi 255W GPS Receiver
Can you charge your garmin 255w wild the unit is off.
Yes. Just leave it plugged into a powered 12 plug. It will stop charging when fully charged.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 255W
No, it may take a little longer if you are charging through the USB port. I normally have mine plugged in while driving, it charges and is in use too. To use GPS with USB. First turn the GPS on (without USB plugged in). Press Battery symbol on screen for about 10 seconds, a test screen will come on. Plug in the USB (bottom of screen shows USB connected). Tap EXIT to return to maps. You can now use it while USB is charging Make sure you turn GPS off before removing the USB cable
Apr 08, 2009 | Garmin nuvi 255W GPS Receiver
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
My gramin c330
my unit is new a xmas gift.i have 3 ways of chargeing the unit.when you charge it in the house do not turn unit on till after the unit has charged.in the car plug it in and the picture of the battery goes away that is telling you it is chargeing in the care.gram6
Jan 14, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
