Question about Sewing Machines
Sewing needle won't move
The needle is stuck down inside the bobbin area & won't budge. I've removed the bobbin, tried the side hand wheel & nothing works.
  • Sewing Machines Master
  • 7,365 Answers
It could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
Posted on Dec 10, 2012
bargainbox
  • 1388 Answers
SOURCE: tangle in bobbin area, stuck needle
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 13, 2008
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
bargainbox
  • 1388 Answers
SOURCE: kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
New Singer 1507- handwheel is stuck.
The bobbin might have a bunch of thread off it inside the compartment here the bobbin is. Also, make sure it's thread correctly, that can goof things up to.
Jun 15, 2017 | Singer 1507
10000 janome jamming fly wheel won't turn
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
I have white D'Lite 1750C the bobbin thread is
try these suggestions
change the needle--use needle according fabric being sewed
clean under needle plate & in bobbin area for lint or threads
make sure the bobbin is not warped or damaged
make sure the bobbin case is not damaged
if none of these suggestions help, then I suggest having the machine checked
to see if there is something wrong with the inside parts
May 31, 2012 | White Sewing Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
Why won't the bobbin thread pick up?
have you tried changing the needle? if it's a new needle is it inserted correctly---flat side to the back of the machine---needle push up in inside the needle holder
have you tried cleaning under the needle plate & in the bobbin area for lint or loose threads?
have you checked the bobbin to make sure it's not warped
have you checked the bobbin is inserted correctly?
if you've already tried these things then the last thing that possible is the machine is out of time & needs to be serviced by a repair shop that have the correct tool to time it
Aug 29, 2011 | Brother XL-2600
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
May 10, 2011 | PfaFF Sewing Machines
Sewing Machines Logo
213 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
