Question about Kenmore 98702 Stacked Washer/Dryer
I have a kenmore stacked washer/dryer that squeaks in the spin cycle. What could it be??
Everything seems to be working until it goes into the spin cycle and it makes a loud chirping / squeaking sound.
I had that problem too. i noticed that is was not flat on the ground. You can also try putting oil on it.
Posted on Dec 09, 2012
agitateme
  • 88 Answers
SOURCE: Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Posted on Jan 17, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
SOURCE: Squeak in Kenmore HE 2plus front load washer when drum spins
We opened the top of the washing machine and there are some suspension springs.
All it needed was some lubrification. Prior to putting the top back on we put a load in
and watched it and there was no more noise.
Posted on Jan 21, 2009
  • 90 Answers
SOURCE: Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Posted on Feb 01, 2010
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Washer will not go through spin cycle
it sounds like it could be the lid switch malfunctioning. the part should look something like this. d668319.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
171 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
