Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
Cant get my external hard drive to work on my pc
My girl friends pc,and a external hard drive she has,which powers up,lights up,seems good,but i cant get it to communicate,threw a usb-with the pc,no manuel-no disk!
  • 3 more comments
  • mikejohnson4 Jan 12, 2009
    i just tested ,by pluging a nother device --same port. its good!
    u must not recieved my response.yes my MP3 player into same port reads fine!and i believe this hard drive is ok,because it lihts up ,blinks intermitedly,and acts like it wants to do its part?
  • Roberta Smith
    Roberta Smith May 11, 2010
    lights on the drive don't mean alot.... go to the start menu... right click on my computer.... select manage... one of the items on the menu on the left is for drives... click on that... is the drive shown in there ?
  • Roberta Smith
    it's very possible that external drive has failed then... are you getting any error messages ?
  • Roberta Smith
    is it able to read any other device thru that usb port ?
    Robert
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
When i power on my pc moniter not started hard disk light not blinking..
Are you powering on your computer and your monitor...
If your computer appears to boot, but nothing on your monitor...
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
If your computer won't boot...
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Aug 05, 2014 | Computers & Internet
Pc wont recognize my hp simplesave 2TB external hard drive
No PC stated
No OS stated. (operating system) nor if PC is internet connected.
no Simplesafe model stated, is it the 3.5" HDD? version
id yes it needs power pack to use it. HDD uses huge currents to start up. and spin.
USB ports?
if the drive fails on all PCs, the drive is bad. (or was erased by grimlin's in the night)
plug in the power pack 12vdc is correct.
do not mix it up with other packs or boom.
then listen to the hdd case with you ear, here it spin up?
if not the pack is dead, or the hdd is dead.
here is the power pack for it sold in stores
see that model number there you forgot, to mention, MD2....~~~~
12V Mains AC-DC Adapter for HP Simplesave 2TB MD2000HB External Hard Drive HS....
the drives can fail and be good.
for many reasons.
  1. bad usb port
  2. usb port driver missing.
  3. OS virus corruptiong
  4. drive fails to spin means no 12vdc power. (bad power pack)
  5. using a laptop and expecting the weak USB ports to start HDD motor, will never happen, on large 3.5" HDD. some cant even start a 2.5"
http://www.pcdied.com/external-hdd.html
Aug 24, 2017 | HP SimpleSave 2 TB USB 2.0 Desktop...
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
Your friend has a Windows XP desktop system that contains important data. He frantically calls you to say that when he turns on the computer, the lights on the front panel light up and he can hear the...
Without trying any experiment I suggest that your friend take the hard disc and recover all the data after attaching the hard disc to a PC or get help from any PC service to give you the cables for transfering to a laptop through the USB.
Apr 26, 2011 | Computers & Internet
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Hi, my Lacie seems ti=o have stopped working. Power seems to go into it as the power light comes on (amber) but then it beeps and the seems as if it does not spin
this is a common issue however its bad news, your inter motor stopt working and there's no point repairing it and you cant get your data back either
Mar 06, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
May 23, 2008 | Western Digital My Book Essential 500GB...
Western Digital 120 GB Hard Drive
Well usually external hard drives are just a regular hard drive in an encolsure! You can try to mount the hard drive to a regular pc using the ide/sata connector(Im not real sure which interface your drive will use). From there you can tell wether its the actual drive that is giving trouble or just the USB enclosure! Most of the times with those name brand external drives its a lil complicated to figure out how to take it apart to take out the hard drive. What you can also do is try(if you get it open) to see if you can unplug the hard drive from the enclosure then power on the enclosure and see if the lights come up green(or whatever color it uses to indicate ready)! if it does then power off the enclosure then re-connect the drive to the enclosure and power on again! Maybe that works! Removing the drive might void your warranty, proceed at your own risk! Good Luck regards, babb
Apr 30, 2007 | Western Digital (WDXU1200BBRNN) 120 GB...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
742 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
