Question about Kenmore 83142 Electric Dryer
Drum gap My Kenmore front load dryer has a gap along the front edge of the drum such that clothes get caught as the gap narrows toward the top of the drum. Dryer seems level and there is no obvious wobble as the drum circles. Any suggestions?
    Problem Solver:
What is the model number?
Posted on Dec 09, 2012
  • 249 Answers
SOURCE: Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Posted on Dec 04, 2007
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
  • 1122 Answers
SOURCE: Someone Help! I've got something stuck in my lint filter vent!!
remove the 2 lint filter screws on the top,remove the back,you will see 4 screws on the blower box to the left(the tall box) remove the box and get that ever is stuck in it,let me know how you do-mike
Posted on Mar 20, 2009
  • 188 Answers
SOURCE: Dryer leaves brown spots on clothing articles.
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Posted on Mar 23, 2009
I have a whirlpool wed5520sq0 dryer the drum seems to be pinching cloths and making marks on them. The drum has a gap on left side looking into the dryer. I can move it and close the gap. Any ideas would...
Sounds to me like either the seals on the front and back of the drum are worn or the glides for the drum are worn and is causing the clothes to get caught between the drum and the usually the
front edge of the dryer. The worn glides will cause the gap that you mention.
Feb 11, 2011 | Whirlpool WED9200SQ Electric Dryer
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
I have a GE DSXH47EG0WW dryer and clothing is getting caught along the edge between 2 parts of the drum. This is causing fabric to tear. Any way to stop this from happening?
if its in the front of dryer you need the front brg and felt replace and the 4 slides . if in rear of drum replace rear barg and do the front . may also need a belt and idler . dryer sounds like if done a few loads .. hope this helps mm
Dec 03, 2009 | GE DSXH47EGWW Electric Dryer
I need to replace the drum seal due to brown stains on clothes.
When the front door glide system on the fex series dryers wears out the drum isn't held in place properly, there is enough of a gap between the bottom of the drum and the front panel for clothing to get in. As the drum rolls and the item moves to the top it becomes pinched as the gap closes leaving stains and sometimes damaged clothing.
If this is what you are talking about, Make sure it is unplugged then remove the slanted panel above the washer lid. remove the control panel (4 screws) it can be unplugged (2 plugs on left side) and laid aside (rubber line can be removed and slid out of plastic clamp.
when the control panel is removed you will find two screws holding the bottom of the front panel, these have to be removed.
there are 4 screws along the upper edge of the front panel that have to come out and then the front will come off.
Reassembly is difficult with this machine (I remove the dryer door if I'm working alone) so try to do the job when you have help.
Good Luck
Quentin
Jul 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Torn clothes
there should have been a plastic gaurd on the lint catcher inside to keep this from happening, at anytime when taking your clothes out did you find something you might have though how did that get in there> could have been it, or look under the dryer and see if it made it's way out past the drum to the floor
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Narrow streak of what looks like grease on clothes from dryer
hi anne-
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
May 09, 2009 | Dryers
Clothes catching inside at top of drum
IT sounds like you have a roller that is broken or the drum is off track...when a roller breaks or the support bracket that the roller is attached to has a screw loose and has shifted position and I surmise based on your description that the front left roller is affected or the drum is off track up toward the front of the dryer...that would make the front of the drum drop creating the situation you described. The only way to get to this problem depending on the brand...is to remove the top of the dryer...or the back of the dryer...and remove the drum...to access the rollers.....be careful to observe closely how the belt is attached to the spring loaded arm (tensioner) that keeps the belt tight...and replace it the way it came out. Any problems get back to me and I can walk anyone with good mechanical skills through exactly what to do.
Hope this helps....please rate me...the Fang
Mar 25, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 83142 Electric Dryer Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
