I need help with a Hermes 3000 typewriter.....Please
Need help with a Hermes 3000 1962 typewriter....please? I have a 1962 Hermes 3000 typewriter that is in excellent to almost pristine condition by the looks of it and I am looking to sell it soon on Ebay. The problem is the keys are not striking the paper. They go almost all the way but not quite. Also the carriage seems to slide across without stopping or locking. I am going to sell this for an elderly women now in a nursing home who can really use the money so I would like to get it working as great as it looks. I think I am just missing something here. I have checked the original instruction booklet that came with it but to no avail. I know it was never abused she was a nun and no kids every touched it. Her mind is gone so she won't even remember it so I can't ask her for help. The machine is super super clean with no scratches from the case or anything. If someone could assist me I would really appreciate any and all help. Thank you in advance.
  • 19 Answers
SOURCE: old remington typewriter
G'day mate, most likely cause is that the drawband is broken/disconnected. Look under the right-hand side of the carriage,you would have to tilt the typewriter on it's back. There you will see a small hook where the drawband should be attached to. If not, set the typewriter on it's feet again and move the carriage to the extreme right then looking down past the left thumb wheel you will notice a drum with the drawband attached. Rotate it until the drawband hook come into view. Get a piece of strong wire about 12 inches long,fashion one end into a hook,thread it through the machine under the carriage,from the right-hand side until it appears just over the drum. Ayyach the drawband hook to it and pull your piece of wire out to the right. You will notice the drum rotating and the increasing tension on the drawband , this good,nothing is going to snap, break etc. Hook the drawband on to it's latch and try the typing. If the typewriter's carriage moves slowly it means that there is not enough tension on the main-spring located inside that drum. Do not depair, because by removing both side plates you will see a large screw on each side of the back cover plate remove these and then you will see the mainspring drum in it's entirety. There will be a winding gear central to the drum,loosen the locking pawl and begin winding in aclock-wise direction to increase the main-spring tension. Test the carriage occasionally for tension.
When all is OK reverse all what you did before.  Cheers and goo luck from Australia....
Posted on Oct 18, 2007
squipps
  • 204 Answers
SOURCE: How to oil/lubricate an old Olympia AG/SM ? typewriter
Hi..sewing machine is ok, a little too light but ok. Move your margins all the way out so that you carriage can move its full length.
If you look at the underside of the carriage you will see what they call Rails. These are tracks in which the ball bearings reside. 4 or 5 drops of oil on these and the bearings will be lubed. I use a little heavier grease not oil, but light oil. Too much oil is worse than none.
I think you problem is in the carriage return clutch..something that should be handled by a Pro.. Too many parts, springs and broken adjustments for the layman. Some times you can spray 1..I repeat 1 small shot of degreaser on the carriage return clutch (located on the right side, middle of the typewriter. Usually has a fabric band winding around it.
If not a Pro can help you..
Hope this helps.
Squipps
Posted on Feb 06, 2008
SOURCE: Olivetti Lettera 32 Typewriter Carriage Stuck Jammed Locked Up rigidly all the way to left.
There might be a little tab below the carriage wheel on the left of the machine. You should be able to move it up or down, and release the mechanism.
Posted on May 13, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Posted on Sep 29, 2008
  • 45 Answers
SOURCE: bought a great smith corona coronet electric 12
Try going to www.willrepairservice.com for a manual for your Smith Corona typewriter. Or, you can go to Google and type in "Will Repair Service", go to the first link displayed in the results. Best of luck to you!
Posted on Jun 07, 2009
Margin release hermes 3000
It's been a while since I've seen a Hermes but i believe the margin release key looks like >//<
DickyO
Oct 06, 2014 | Office Equipment & Supplies
How do I releaseor move the right margin on a Hermes 3000
You either squeeze the margin stops or push them down, they may be stuck so a little light machine oil on the margin rails should move them.
Jul 19, 2014 | Office Equipment & Supplies
Typewriter carriage
The typewriter needs the escapement adjusted, or you have a bind in the escapement, and it probably needs a good cleaning and oiling. This usually done by a pro.
Oct 07, 2013 | Office Equipment & Supplies
I have a Hermes 3000 typewriter. Once I set the left margin, it's not sitting there. It moves fast to the right margin. I am not able to type a single word because of this. Is the mainspring is bad? ...
The mainspring is not bad or the carriage would not move that way. It sounds like and escapement problem either from the carriage release sticking, the escapement itself needing adj. which you probably cannot do, the escapement rack is bent or maladjusted, or the tab function is sticking or maladjusted. Check the carriage release levers to see if they are sticking. Also make sure the tab function is knocking off so the carriage is not in constant tab mode. Hope this helps.
Oct 07, 2013 | Royal Office Equipment & Supplies
Where can i get a manual for my smith-corona typewriter?
Can you give us any help in identifying the machine? Is it manual or electric, for example?
There's a downloadable and printable manual for the Smith-Corona Standard Portable here.
Bear in mind that if this is an old typewriter then there is a very good chance that no one has bothered to rewrite the manual since the invention of the internet. In such cases the best you can expect is a scan of an old paper manual.
Mar 29, 2012 | Smith Corona Office Equipment & Supplies
Hermes 3000 carriage is "locked."
I think there's a lock there in the spacing. Mine can be locked by pulling the spacing lever far upward. Just set your spacing and I think it will unlock.
Apr 18, 2011 | Office Equipment & Supplies
Hermes 3000 tab stuck in middle.
After you press the margin release key, space to the desired R. margin location, press the R. MAR key.
DickyO
Jul 10, 2010 | Office Equipment & Supplies
Hi, I need to know how to set the tabs on my Hermes Baby typewriter and how to tab to the set place. No manual, and it has me floored. Has a key on the top left row with two arrows on it, each pointing in...
On the top row there should be 2 keys one + one - these are the set and clear tab keys. Theone with the 2 arrows is the margin release key there should also be a key that says tab that will move you rfom tab to tab.
DickyO
Feb 10, 2010 | Office Equipment & Supplies
I have an old Hermes 3000. I was in the middle of typing away and the machine was working perfectly. Then all of sudden the carriage will no long stop. It just slides directly to the right margin and stops...
It might be that you tab key is engaged which would do this. also try gently moving the carriage to a point, pressing the space bar and then releasing the carriage. It might be the escapement..
Hope this works!
Dec 09, 2009 | Office Equipment & Supplies
133 people viewed this question
k24674
