Fujitsu Inverter ASTA24LCC has flashing "Operation" and sometimes "Timer" lights. I have cleaned filters but the lights still flash. Does anyone know the issue here?
  • 242 Answers
You may need to open the louver and hold down the Manual/Auto button for 10 seconds to see if you can reset the machine. Additionally, unplug the unit for 30 seconds or so and then plug back in.
Posted on Dec 10, 2012
  • Gary Russell Dec 19, 2012
    Thanks for your suggestion Chuck. Unfortunately it didn't fix my issue this time by I appreciate your help. I think I will need to call this in for a service.
Geekman
  • 32281 Answers
SOURCE: Fujitsu. Wall mount AC inverter. Operation ,timer,and economy lights all blink, I clean the filters but no change , unit is only 3 months old..
Your AC unit should be still covered by warranty, get the installer to check you AC unit.
Posted on Jan 30, 2012
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: I have an ASTA24LCC split system and the unit is
Voltage issue? There should be a diagnostic chart on the wiring diagram.
Posted on Mar 01, 2010
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
I have a Fujitsu ASTA24LCC heat pump and it has stopped going, but is showing some form of fault code. Operation & Timer lights flash together twice then operation light flashes 5 times. What does...
Aug 11, 2008 | Heating & Cooling
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
4,160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
