Question about Cell Phones
Hi do you have battery and battery cover for samsung gt b7210 all black model
Battery and battery cover older all black model about 1 yr old
edcarson
  • 10 Answers
SOURCE: "clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Posted on Feb 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Takes much longer now to heat things
I think you have two separate problems.
Taking a long time to heat is almost always a failing magnetron.
The cover on the side is the waveguide cover. If your waveguide cover is burned or broken, it will need to be replaced.
It protects the waveguide and magnetron from grewase and food particles, which can cause arcing and damage.
Hopefully your oven is just under the one-year mark and GE will fix it free under warranty.
Otherwise, they will replace the magnetron at no part cost, but labor will be your responsibility.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 10, 2008
  • 12 Answers
SOURCE: Hi. We have a 3 yr old top-o-the-line Samsung
turn machine off at power point the door should then unlock after a couple of minutes. Drive belt may be broken as well.
Posted on Dec 22, 2009
  • 93 Answers
SOURCE: 2-yr old ESQ Model 07301076 stopped running
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get age of conan gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: Video on Samsung FPT5084 suddenly went out today.
Yes. Several people on this website have reported this problem. I, myself, have had it fixed 3 times now.
Posted on Apr 12, 2010
Is there a way to get to the data of my old Samsung Galaxy Note 1 if it does not start?
Hi. It's most likely that the battery is completely dead - beyond resuscition if you like. Your phone might power up with the charger after removing the battery or a battery could be had for a few pounds on Amazon or ebay. Check your model
Apex NEW OEM Replacement Battery For Samsung Galaxy Note 1 EB615268VU GT...
Jul 26, 2016 | Samsung Galaxy Cell Phones
How do I open the back of a S4 Samsung galaxay cell phone
Samsung Galaxy S4: How to open back battery cover:
1) Flip the phone over so you see the back cover..
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-5.jpg 2) Locate the notch on the side of the phone with your fingernail and pull the cover easily up to unlatch that area and all areas around the phone.. With one hard pull you can easily take off the whole cover.. don't be shy, your Samsung phone is sturdy enough to handle it.
All the blue arrows in the below image shows where the cover clicks into the inside of the phone to keep it closed.
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-9.png 3.) when you need to put the cover back on the phone.. place the cover over the back part of the phone, noting that the camera hole in the cover goes at the top..
Then grip your left hand on the left side of the phone and your right hand on the right side of the phone.. apply pressure to each side to click the latches to the phone locking it in place.
Afterwards, run your fingers along the back sides of the phone to see if there are any bulges (a latch may not have clicked in place). Either apply pressure there to click it into place or you may have to take the cover off again and try again.
It's very simple and easy once you get the hang of it.
How to Open Samsung Galaxy S4 Back Cover Insert Battery SIM Replace Back...
Bending the back cover will not damage it because it is plastic.. unless you bend it to crease it. Below is Samsung's durability test.
https://www.youtube.com/watch?v=UrhCz6PnT78
(you may need to copy and paste this link to make it work)
Jan 18, 2016 | Samsung Galaxy S 4 GT-i9500 Smartphone...
My samsung GT-B3410w won't turn on, I press the "on" button, it loads the phone, but then it gets stuck on a black screen with writing " SAMSUNG mob!le" and thats all. What can i do? is there any
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Dec 01, 2012 | Cell Phones
Quit working no reason 1 yr old..has new bat on it
On this model there is no fuse in case you test to high of a voltage. So My thoughts are maybe the small spring fell out when changing the batteries or ( I am not being smart ) you put the batteries in backwards. Also try another set of batteries and of course a circuit you know is live. Mine is 5yrs+ old and have never had a problem with it. If tis doesn't work they aren't that pricey I would just get another one.
Feb 01, 2011 | Greenlee GT-11 Non-Contact Voltage...
I have the intova ic 8oo uw camera Problem is the battery cover wont hold the batteries in can I get this repaired. only 1 yr old .rgd gerry
Hi Gerry,
Sorry for the trouble. We can replace the cover for you at no charge. Please contact me at kevin@intova.net and I'll be more than happy to send you a replacement cover and directions. Its really simple and takes about 30sec. Just leave me your address and mention you need the battery cover and I'll send it that day. Take care
Oct 14, 2010 | iClick Intova IC800 Digital Camera
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Battery runs out fast
If the battery, is more than a year old, it has reached its charging limit. Batteries usually last a year or on there charge cycle. If the system is within 1 yr of purchase you can contact compaq technical support to get it replaced.
Thanks
Proton
Jul 13, 2009 | Compaq Presario CQ60-220US PC Laptop
Feb 18, 2008 | Samsung TXM3281HF 32" TV
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
