Battery not charging
Changed battery but still not charging. charger is ok
    Novelist:
    Champion:
  • 233 Answers
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Posted on Dec 10, 2012
  • 7,627 Answers
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Posted on Dec 09, 2012
Why is it not charging?
1 Battery no longer holds a charge
2 Charger is faulty
33 Charger circuit does not function
This is assuming the mains socket works ok
Try a different charger, if that does not do the trick you know it is either batteries or charging circuit. Then change batteries, if that does not work you know it is a charging circuit fault
Jun 11, 2015 | Tablets & eReaders
Why green light on charger dose not flashing during charging
I assume it used to? you may have a faulty charger (if you know some one with another charger you can borrow you can see if that works and if so you need to replace the charger, remember to check the charging amp's on your charger and make sure the one you borrow matches yours, form instance if your changer is 24volts @ 5 amp you need the same charge rate, you can go lower but not higher.as you may damage the circuitry, if the charger is ok then you have probably got a shot circuit on the chair. or the batteries are damaged (if you have a car charger and you can remove the batteries try to charge them with that and see if they take the charge, if not then it is your batteries that need changing)
hope that helps
mark.
Aug 29, 2014 | Health & Beauty
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
Ryobi charger bcl1418
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Oct 08, 2012 | Ryobi Drills
My nokia 6220 classic was ok when i was going to sleep but at Morning its not switching on and not taking charge. When i connect my phone with charger it is becoming little hot and showing no charging...
there must be some problem in battery charging.change the battery and charge it.this will mostly helpful to you.if same problem exist means.then check the charging pin in your charger and in mobile too.if so try to change the charging pin of your mobile.
Dec 27, 2010 | Cell Phones
My phone is not charging. when the charger is connected it shows the battery icon blinking as while on charging. but it is not charging & the battery was also OK .
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 11, 2010 | Motorola Mobility ROKR E6 Smartphone
Cant able to charge the battery in dell 600
first check your charger cable that everything are ok. if not then tell me is your computer run only from your battery back up. if not then i think your battery become weak. so it is unable to keep charge. then the way is change your battery and buy original battery from Dell show room. but if battery ok then change your charger.
thanks
Mar 06, 2010 | Dell Latitude D600 Notebook
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Battery charge problem
your batery is ok,try to change your charger.your charger is old or bad and probably overheating.
Feb 07, 2008 | Toshiba Satellite A75-S209 Notebook
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
