These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sounds like a bad cap, check the power supply's again, if you are yousing a multie meter you will not see power supply ripple try a scope or meter in the AC position for DC components this might show up
When it stops post here what blinking lights are on. Belt should have some movement. If you hear the motor straining but the tub is stuck then it will be worn, hot and flaking. The water pressure switch can stop the unit The safety switch can also stop the unit for out of balance. I would reload the washer and check if level as well. Then see if you get the blinking lights.
My unit shut down in the middle of the night and had the blinking STOP on a dark screen, would beep 10 times when plugged in aswell. I set the unit on top of a pan and opened the bottom water drain plug. After draining alot of water out the unit allowed itself to be turned back on again. Guess its either extremely humid or the dual hose setup doesn't evaporate the water as fast as they made out. Anyways, I haven't found anyone else post this so I hope this helps someone out there.
To find a code for your Haier TV with the URC-3021, you will need to use the auto-search function of your remote.
To search for a code for your TV: 1. On the remote control, press TV once. 2. Press and hold SET until the LED (red light) blinks twice, then release SET. 3. Enter 9 - 9 - 1.The LED will blink twice. 4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER). NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first. 5. To lock in the code, press and release SET. The LED will blink twice.
