Question about Frigidaire FER641FS Electric Dryer
FUSE LOCATION ON DRYER
MY DRYER WONT HEAT BUT WILL TURN AND I AM TRYING TO FIND THE LOCATION OF THE FUSE.
  • Frigidaire Master
  • 8,220 Answers
It is on the upper right hand side in the rear:
To access it you pop the top then remove the front panel then get the drum out I have videos and a service manual HERE on my blog page.
Posted on Dec 09, 2012
How do i find the thermal fuse on my samsung dryer dv350ae
Go to www.repaireclinic.com and enter dv350ae. You will be presented with a list of common repair parts and may be able to view a generic Samsung video that shows disassembly and parts location.
Oct 08, 2016 | Samsung Dryers
Location of fuse model WER211ESO dryer
The fuse is probably related to the mains plug fuse and unlikely to be this as the machine switches on. Possibly the heater or heater thermostat. You may need a engineer to confirm which one.
Jan 17, 2014 | Electrolux Dryers
Dryer will turn but will not heat
Dryer wont heat if the thermostat/thermal fuse is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 29, 2010 | Whirlpool Dryers
Dryer turns but has no heat, fuse location?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
The heat will not engage
Try to check the fuse sometimes depending on the dryer the fuse will go out and stop all heat if that is the case all you have to do is replace the Dryer fuse
Jul 13, 2010 | Amana NGD5200TQ Dryer
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
Frigidaire FER641FS Electric Dryer Logo
308 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
