Question about Onkyo TX-SR707 Receiver
Tx 707 reciever will not enable speakers
My son played around with my remote and then turned off the receiver. When I turned the receiver back on, speakers would not turn on. I tried different buttons on the remote and nothing happened. I turned it off and then back on again and the speakers came back on. When I turn the power off and back on again, the speakers do not turn on again. Not sure what is going on?
techman
  • 3130 Answers
SOURCE: Onkyo TX-SV434 "Protect" light
The protect mode is a built in safety message, indicating that theres a fault somewhere with-in the unit, and it wont let the unit come on fully or more damage will occour. This unit is a solid state device, and you should not attempt to use it or open it or try any self repair as it will cause more damage. If this unit is more then a few years old , it might just be the time to start looking around at all the back to school sales on electronics, as to have this unit serviced will cost an estimate fee as well as parts and labor. If you want to invest a few bucks into this machince , then go for it, but its most likly will cost 1/2 or more then the cost of the entire unit did when it was new to have it repaired. It is up to you. Good Luck
Posted on Aug 09, 2006
futureloginn
  • 734 Answers
SOURCE: I have an Onko TX 8511. It will not Power On
as follows to our chat session, please rank me for the solution.
Posted on Nov 16, 2008
SOURCE: Onkyo tx-vs515pro won't turn on
doubt that reset will fix your problem---but here it is if you want to try:
hold down the cd button and press the power button [at the same time]
test will [should] appear on screen for about 5 seconds--you need to unplug the set during this 5 second period. this resets the cpu chip.
hope it helps solve your problem.
barnesmar
Posted on Feb 15, 2009
SOURCE: Onkyo TX-8211 receiver with very low volume through speakers
It's the Tape 2 button - unclick it.
Posted on Jul 09, 2009
SOURCE: I have an onkyo TX-SV515 PRO receiver and the
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
Posted on Aug 11, 2010
I have an onkyo TX-SV515 PRO receiver and the remote speakers will not turn on. The main speakers work fine but when I depress the button to turn on the remote speakers they do not switch on.
Jun 05, 2010 | Onkyo TX-SV525 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
My sansung remote control 2 dvd at the same time...how to have only one remote for each
When attempting to increase the volumn on the television either using the remote of turning the reciever knob by hand the volumn increases dramatically. I am concerned the speakers might blow. Does anyone know how what the problem might be.
Jul 05, 2009 | Onkyo TX-SR705 Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Linking DVD/CD to Receiver
You use rca cables to hook them up to each other. On the back of your Reciever make sure it is hooked to the cd. There should be speaker outlets in the back of the reciever. You should have suroundsound, Center, left and right speaker ports. I've never seen just 2. Crazy
Oct 16, 2007 | Kenwood VR-707 Receiver
Speaker switching problem
What the type of switch you have there? its like a push button or a soft button? Often you have a contact switch problem on your unit. I f can access the switch contact and clean it that maybe can help on your problem.
Aug 03, 2007 | Onkyo TX-DS747
Reciever turning off.
You have a short in the speaker wiring. Simply put, the pos and neg (red/black ends) of your speaker wire are most likely touching somewhere. The receiver has a short protection circuit that keeps you from blowing the receiver or your speakers. Either try re-cutting the ends of the speaker wire, or if that doesn't remedy the issue, buy new speaker wire.
Jun 18, 2007 | Onkyo TX-SR601 Receiver
Onkyo TX-SR707 Receiver Logo
16 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
