Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Low flame on left front burners high flame onright front burnners
My front left burner is very low in the hi knob pos. my right front burrner is very high in the hi knob pos can I adj ??
    Top Expert:
  • 2,899 Answers
Sometimes the burner holes get clogged. I use a toothpick to clean out the holes.
Hope this helps.
Posted on Mar 21, 2015
    Problem Solver:
  • 7 Answers
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Posted on Dec 09, 2012
gwshaw71
  • 83 Answers
SOURCE: gas stove top burners
Make sure nothing is blocking burner tubes and burner tops. All holes need to be free and clear. If that dont work replace your inlet valve were your gas lin goes in.
Posted on Dec 08, 2007
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: All knobs are in the off position but the right
Your switch for that element is bad and must be replaced.
The contacts inside the switch are welded together.
Posted on Jun 24, 2009
milten1
  • 1304 Answers
SOURCE: Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Posted on Oct 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: while using kenmore 790.9621 smooth
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Testimonial: "Thanks for your answer. I've been upside down with this thing! I put a new 4 prong 40amp cord on it and it looks like it solved the problem. Thanks "
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
I have a 3 burner CaptnCook gas grill. The middle burner has a single flame when I try to light but does not light the whole burner row, just right at the front only. The right and left will not light at...
The problem lies with the grill's regulator and how the gas tank valve was opened.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Fire burns good for a while then wants to go out
Flame sensor at furance burrner conpartment needs to be cleaned. Flame sensor is located at the left of the burnner compartment fsarthest burner tube from ignitor. Remove and clean with very fine grit sand paper 400 grit works best.
Jan 26, 2011 | Heating & Cooling
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
198 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
