Question about ASUS G73JHA1 Notebook
My asus laptop display is showing a blue or purple haze bar through the middle.
My laptop is showing of a blue line or bar going through the middle of the laptop and it's causing a purplish haze to my display making it unbearable to play games or anything requiring graphics. If it's not black and white it looks trashed. I deleted and reinstalled the Video Drivers. The HDMI output shows no video card problems as it gives a clear picture to the tv screen I used. So I'm guessing the monitor is going bd, but I want to make sure before I rush to best buy to honor my warranty.
  • 46 Answers
Sounds like you are right there do it before the warranty runs out!
Posted on Dec 14, 2012
PauldLucky
  • 268 Answers
SOURCE: Asus L7200 without video driver
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
or
You can also try this :
http://tinyurl.com/brslmb
Good Luck.
Live, Love, Luagh.
Posted on Feb 01, 2009
Znyp
  • 12 Answers
SOURCE: connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Posted on Mar 14, 2009
  • 460 Answers
SOURCE: Just purchased an asus k60 from best buy
that was your first fatal mistake downloading mcafee..you have to totally restore the operating system. good luck
Posted on Nov 09, 2009
Davethesnake
  • 689 Answers
SOURCE: white screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
Posted on Sep 04, 2010
  • 846 Answers
SOURCE: Asus x83v screen is black and has vertical lines on half of it.
connect an external monitor, if the issue is not there, the problem is with your LCD . You can get the part at Asus Repair and there is a guide that shows you how to put in the part at Netbook Repair Guide.
Posted on Apr 12, 2011
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
The picture has a purple tint to it, the TV displays one until it warms up. How can I fix this???!
Older TV units have a tube which is where the picture displays. It sounds as if the green firing beam could be failing which leaves the blue and red firing beam working causing you to get a purple haze on the screen. You might be able to get it repaired, however more often than not it is much cheaper to buy a new tv set.
Oct 03, 2012 | Televison & Video
Screen is going crazy
Okay, it could be two things, 1.) Your graphics card is either overheated or going out. 2.) it's possible you have a messed up display screen. I'd try looking at your computer display settings and see if you can calibrate the color on your screen to see if it helps or not.
Jun 05, 2012 | ASUS K52F Notebook
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
When plugged into laptop, projects images with a purple haze
This will depend on the brand, model, cable connection type and OS of the laptop. Most have a color control which you can adjust.
Dec 05, 2011 | ViewSonic PJ350 Multimedia Projector
Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Mar 08, 2010 | Sony KDF-E50A10 TV
Blue strip (Haze) started showing up in middle of screen.
you need to chang screen or buy new tv ,cause that is not fixable its killed pixels.please leave comment,vote,note.thankyou
Sep 13, 2009 | Hitachi 50V720 Television
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
ASUS G73JHA1 Notebook Logo
159 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
