Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Plastic knobs on gas range get too hot/ want metal ones
I have a GE gas range model# JGSP28SEK4SS with plastic control knobs. They get very hot and I want to replace them with stainless steel ones. I cannot find them anywhere. Any suggestions?
SOURCE: Condensation
Cheap fan bearings dry out and start to bind, slowing down air flow. This creates condensation and then ice on top which will screw up control board. Try to get help from Sears and you will always get INDIA. This is why Sears in a failing company. They don't care about you!!
Posted on Jul 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Posted on Aug 20, 2008
SOURCE: model 795.77309600
call a service tech from Sears, this is a fire hazard,light control is bad,apparently, modification includes thermal switch,to turn off lights in the event of failure.
Posted on Nov 08, 2008
SOURCE: Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Posted on Dec 10, 2008
DeBruce
  • 145 Answers
SOURCE: scratched stainless steel
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Posted on Aug 24, 2009
All the knobs on my lg gas range need to be replaced. the plastic part in the middle of the knob jst did not last and the replacement for all five knobs is at least one third of the total cost of the...
I have a $1.50 per knob solution: 1. Buy a 1/2 x 5/8 x 1 spacer at Lowe's ($1.50 each - get 5 pieces) 2. Clean knobs, remove back cover of knob and connect broken plastic parts with glue (liquid form). Make sure little metal inside the plastic is on front end. 3. Apply glue (gel form) around plastic then slide the metal spacer over. Add more gel glue to fill up space between plastic and metal. Might want to wait 30minutes then apply more glue if there is still space or gap. That's it! I recommend waiting 24 hours to let glue cure until putting it back on range. Now you can put cap back on but would need to make the whole a little wider using a grinder.I used a small flathead screwdriver and a hammer and just chip off small pieces until metal sleeve would fit. However, I think u can do without the cap if you have strong glue. I have pictures. Feel free to contact me for questions: cbraza@yahoo.com My wife is very happy, saved her a lot of money coz new ones cost as much as buying a new range itself! The knobs are very sturdy right now. Wide says it's actually sturider than when we first got the range.1_25_2013_5_53_38_am.jpg1_25_2013_5_54_22_am.jpg1_25_2013_5_54_47_am.jpg
Sep 02, 2011 | LG LRG30855ST Stainless Steel Gas Range
Searching for plastic push on control knobs
Hello.
I search it however, not to find the replacement parts, in this case i would rather suggest you to contact the vendor of your kleenheat, maybe they know where to find the service center of that machine or their tech maybe can cater the problem.
mlenavz
Apr 01, 2008 | Magic Chef 31000 Gas Kitchen Range
GE Gas oven not coming on (ignitor not glowing at all) ge jgsp28sek4ss Broiler works, stove top works, oven igniter not coming on Thanks Jim
The ignitor just needs replaced . you can find the parts using your stove model # . its two screws and a wire to replace .
Feb 05, 2011 | GE Kitchen Ranges
Knobs on range do not work properly. need to replace them
Hi- Give LG a call, I did replace some once on a range and LG sent them out at no cost to the owner. Just have your model and serial number. Good luck
Sep 24, 2010 | LG LRG30855ST Stainless Steel Gas Range
Knobs wrinkle on my LG LGR30855ST range.
The plastic shaft on the knobs split and loosen. I have the solution for that, but I need one metal insert that goes over the gas valve shaft and into the knob. For those that have the split knobs. This a bit of work but it works great. Remove the two screws from the back of each knob. Go to a hardware store and find the thin brass tubing that most have. Pick the tube that just about fits over the plastic shaft. It will fit over the tip but will not slide down the shaft all the way. Now pick a brass washer that the tube almost fits into. (You have to do a bit of tooling on both the washer and the plastic shafts. What you will end up with is a brass tube soldered to the washer that fits over the plastic shaft and is screwed to the metal insert in the knob from the inside. First take the tube and file across the top of the tube to make teeth. Now slide the cutter tube down each shaft while rotating it. This cuts the shaft to exactley fit the tube. Drill the washer to also exactly fit tube and cut or file the washer to fit into the knob at the bottom of the shaft. Cut the tubes to length, press fit them into each washer (this should be very tight and solder each washer to the tubes. Place the soldered unit on to the plastic shaft of the knob. Drill two number 4/40 size screw holes into the washer. One on each side of the shaft. Just start the drill into the metal insert. Do not drill through now. Remove the metal insert. (take a small screw driver and put it into the space on either side of the metal part of the knob. Not between the metal and the plastic knob though. that may break the plastic. The metal insert comes out fairly easy. Once it is out finish drilling the holes with a 4/40 tap drill. Tap the drilled hole with a 4/40 tap to make threads. Screw the tube and washer assembly to the metal insert. The screws should be flush with the back of the metal insert. Place the metal insert back in the knob. You now have a sleeved knob that will never break again. This is how it should have been made in the first place. I did this in a few hours on a Sunday afternoon. The parts including the 4/40 drill and tape were about $13. It is not as hard as it reads. LG has a quality issue, but does not want to step up to it.
Oct 19, 2009 | LG LRG30855ST Stainless Steel Gas Range
Burner knobs melt on GE Profile XL44 gas range.
I had the same problem and searched extensively for a solution. They even have a video from GE on the net telling you how to avoid melting them, which is basically don't open to broil and make sure the seal is good on the oven. Essentially, don't use their oven normally like the rest of the ovens in the world. Finally I went to a few show rooms to look for a knob to substitute for the garbage ones from GE. On one of the new models they have a solid cast stainless knob (with a plastic shaft, I think it is delrin) which looks identical but has a longer shaft. I obtained the PN which is WB03T10262 and ordered one. I trimmed the shaft length to match the length of the defective knob with a hack saw, and had to trim out some mold flashing in the cavity. After a couple of fittings I was finshed and it looks fine. I then ordered 3 more from the Appliance Zone for $15.98 each. GE's price for the same part was $25.25!!
Jul 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile range knobs melt
Same problem as well. Hoping to buy universal fit parts as GE wants $16/piece (x6) to replace the knobs. They WILL NOT cover under warranty.
HORRIBLE SUPPORT, POOR QUALITY PRODUCT!
Jun 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need metal replacement stove knobs.
I was able to find online some metal knobs that MIGHT work, but the prices ranged from $30 to 60 EACH, and I needed 5 - too costly for me!
The following 3 plastic knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
I have installed the Amana knobs (#1), and I will report back if it proves unsatisfactory.
Dec 20, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
