Question about Stiebel Eltron 3-2 Tankless Electric Water Heater
Sistem turns off shortly after I reset it
I push the reset butom and there's hot water, but about a minute later, hot water stops flowing. If I want hot water, I have to reset it over and over again.
  • sybrer Jan 28, 2009
    I have exactly the same problem :- no hot water, then after pushing the red reset button the light comes on and i have hot water for about 30 seconds then it trips and switches off again.. no hot water. If anyone knows of a solution please could you help. thanks.
  • cayeyraf Apr 29, 2009
    The red button turn off after 30 seconds to 1 minute.
    Champion:
  • 248 Answers
Overheat stat or fan
Posted on Oct 12, 2009
  • Brian Marvin
    Brian Marvin Dec 23, 2017
    I have 2 Stieble Eltron tempra 24's. after about 6 months both would not shut off after water stopped. they replaced each one 3 times and after approx 6 months the same thing. They can't figure it out. Problem is not heavy water. i believe software problem. nice when they are working but they really have to work on this. I have to switch to another brand.
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
The thermal cutout, on the left side, pops up when water stops flowing through the unit. The modules are Polymer. I can press the button, have tons of hot water as long as the water is flowing through...
The left canister probably has a grounded element in it, which will keep power going after the water is off. Either that or you have a bad triac on your control unit
Nov 03, 2013 | Bosch PowerStar AE115 Tankless Water...
I installed a new water heater it has power to it but it is net heating up, is there a reset button if I tripped a breaker within the unit
First a question. Did you fill the water heater until water ran freely at the hot taps.
If not you may have had an air pocket and blown an element. Water heaters will
always be shipped with the ECO in the reset position. The reset is a RED button
located under the upper cover for the thermostat. Shut off breaker to water heater
and remove this cover, and the fiber glass, then push the reset. Replace the fiberglas
and the cover securely and turn on power. You should actually hear the heater in most
cases. Remember that it takes about 45 minutes for a full tank of hot water from startup.
Feb 27, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
81sv-300 Breaker was turned off then back on. 8 hrs later no hot water. breaker was found to have tripped. turned on but still no hot water. thermostats were found to have been at top:140,...
The button could be stuck on the thermostat or needs replacing. You try to reset it by putting the screw driver head against the reset button and bump the handle with your hand to try to free it up. I have tried that and it free up one, reguardless if it didn't you would have to replace it any way if it is bad.
The button should pree in to reset, also check element's out they can short and throw your breaker.
Jul 29, 2010 | Rheem 81VP6S/430126 Water Heater
Push the reset butom and there's hot water, but about a minute later, hot water stops flowing. If I want hot water, I have to reset it over and over again.
Too many possibilities to solve without being there. If you have to reset it, that means that one of the many safety switches kicked in. Be careful that you don't make it a habit of resetting it without getting it checked, doing so will mostly likely cause a lot more problems.
Mar 18, 2010 | Stiebel Eltron 3-2 Tankless Electric Water...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Stiebel Eltron 3-2 Tankless Electric Water Heater Logo
378 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Vernon Taylor
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
