Question about Honeywell HT-800 Table Fan
I can not figure out how to take the cover off of the fan so I can clean it.
What a stupid solution! You will ruin the motor and switch, not to mention cause corrosion. Take the fan apart and clean it.
Posted on Jun 27, 2010
  • 242 Answers
I have the same 1 , I take mine outside and hose it out , dont spray the switch so much and let it dry very well before plugging back in.
Phil
Posted on Jan 12, 2009
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
I put in a new Living Air XL-15 fan but no go.
Make sure that the pin on the back cover penetrates deeply enough into the unit to activate the power. I too couldn\'t figure out why mine wouldn\'t start until I pressed hard on the bottom right corner of the back cover. When I did the unit started immediately because the pin wasn\'t fully inserted. To solve the problem I held the cover tight with a piece of duct tape and haven\'t had a problem since.
Dec 13, 2013 | Alpine Air XL-15 Air Purifier
How much would it cost to clean my laptop's fan?
It really will only be the cost of some compressed air. The venting on most laptops will allow for the majority of any dust or debris to be blown out of the laptop through the grill covering the case fan on the bottom of the laptop or out vents on the back and sides of the laptop.
Dec 16, 2012 | Computers & Internet
How do i clean my Duracraft Tower Fan Kaz Inc DY012
I just figured out how to take off the back of the DY-012. You know about the 2 screws on the top, in the 'handle' area. But there is a third screw on the bottom. It is hidden by a small button-sized piece of plastic used to cover the hole the screw is in. This piece of plastic has a pin-hole that you can stick a pin (haha) or a paper clip in, to pop it out. After the 3 screws are out, you pull the back away from the front starting from the bottom, and when you have loosened both sides of the back, you pull down to remove it from the top. You should also see a small **** at the top. Stick a very thin screwdriver or knife in it to help unclip the back from the top. Once you have access to the inside, you just have to figure out the order in which to remove screws to have access to the harder-to-get-to screws. I must say, the plastic cleans VERY easily! My fan was covered with nicotine which accumulated extra dust and dirt, and it now looks brand new!
Sep 30, 2010 | Duracraft DY-012 Tower Fan
Fan is loud
If you can manage to open the bottom cover, clean the fan blower or replace.
Aug 19, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
How To Clean
On the back of the fan there are 6 recessed phillips head screws around the circumfrence of the fan. You must use a longer screwdriver as the screws are set in a couple of inches.
The two screws on the bottom are a little harder to see.
There are also two clips on the sides front cover. Squeeze on the sides gently to release these.
Jun 28, 2008 | Lasko 3440 Wind Tunnel Floor / Box Fan
Sony pcg-k35 cleaning
I had to figure this out not long ago.
First you need to pry up the piece of plastic trim that covers the speakers at the top of the keyboard.
Next romove the screws that hold in the keyboard. they will all be along the top of the keyboard.
Once that is out of the way. Remove the screws that secure the metal sheild plate and remove the plate.
You can now see the two fans. If you follow the air ducting from the fans there will be some peices of a tape like material that once pulled back will give you access to the airway to the cooling fins. This is were you will use compressed air to blow out dust build up.
It is also a good idea to clean the fan blades.
Once this done, replace the tape covers and reassemble.
I hope this helps because I couldnt find any info on this on the web.
Apr 01, 2008 | Sony VAIO PCG-K35 Notebook
Cleaning
cleaning the tower fan consists of this, i took the time to figure it out! unscrew top two screws on back of tower fan. then on bottom of tower fan is a screw cover,(pin size hole in middle of circle) pull cover off. unscrew hidden screw, and now with a little force it should pop right off. it exposes the filter and all it interior. front screen does not come off. oh yeah,your welcome!
Jun 08, 2007 | Tower Aloha Breeze Fan
Honeywell HT-800 Table Fan Logo
1,056 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
