Sony lcd tv black screen 3 flashing red light model kdl32s2010 can not reset
Having trouble to set factory restore power voltage ok
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Over Voltage Protection 03
Check the site linked below. As stated above, three blinks are the symptom of over voltage. If an over voltage comes out of the secondary side of the SMPS power board inside, this type of indication will occur. You have to troubleshoot and repair the main power supply regulator board. In most cases, it might need replacement, as components to this board are not easily available in the open electronic spare part market.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Blinking codes, and fault finding are described in detail here.
Posted on Dec 09, 2012
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 979 Answers
SOURCE: Videoseven (V7) LTV32DA LCD TV black screen, blinking led
That is correct in assuming that this is a code and it is related to that on-board processor protocol. Yes, many screens are used on many different chassis, but the ways to the means is not always the same. So, you have a schematic for this motherboard? What problem are you having with this set?....accordianman
Posted on Feb 27, 2008
experttv
  • 203 Answers
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Posted on Sep 11, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
Sony bravia kdl-40w600b..turns off after switching on..and the red light indicates 8 time..whats the issue..and need to resolve
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
How to service fix phones tablets PCs TVs and tech reviews blog by Tampatec
Factory reset:
https://us.en.kb.sony.com/app/answers/detail/a_id/43126/c/65,66/kw/factory%20reset/session/L3RpbWUvM...
First I unplugged my HDMI cable and powered OFF my router (using wireless).
As soon as HDMI 1 showed on screen, pressed the arrow up button on remote, touched the power button on left rear side (uppermost) button on my TV) and let go of arrow up. TV said RESET and after a min, TV went back to setup screen. Followed Setup onscreen instructions and working OK.
May 11, 2016 | Sony Televison & Video
Have a hl61a750a1fxzc(model) tv, tv is about 5 years old. Tv has a greenish picture tint... Looking at http://ww2.justanswer.com/uploads/TVTech1/2010-07-02_101408_SMPTE_Color_bar.jpg top 7 colors on my tv...
please do this test: God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Aug 01, 2013 | Samsung Hl61a750 61" LED Powered DLP HDTV
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
My Sony Bravia TV won't turn on, a red light flashes twice every few seconds but nothing happens., the screen is still black. Please advise what i need to do asap.
Tries tv unplug,replug it back like about an hour later.The tv will be resetting back to the factory setting.Now the tv should be working again.If it have the same result.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 13, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
No picture on my lcd tv, sound but just a black screen, no warning of something wrong, just turned on tv one eve and no pic.
1 Check the antenna/cable connection 2 Connect the TV to the AC power outlet and press power button on the TV 3 When the indicator light(standby) lights up in red, press the on/off switch on the remote. 4 If this does not work, reset all settings to factory settings by going through menu and selecting settings
Jan 14, 2010 | Televison & Video
Sony wega crt tv wont turn on red light flashes 7 times thats it
this problum is inside of tv-set
pls. check output voltage from EHT any one output daiode is sort /or open then check and replace with new
if ok then eht screen voltage reset from eht screen preeset and check h- line or blanck rester light
if H-LINE then check vartical B+ voltage /replace vartical ic. or capaciter
Oct 26, 2009 | Sony Televison & Video
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
