Question about Dell XPS M1530 Laptop
Xps M1530 error code 2000-0322
Black screen
  • Dell Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Posted on Dec 09, 2012
  • 10406 Answers
SOURCE: Need to unlock a Dell XPS M1530
Turn the computer off.
Remove the battery.
Disconnect the AC adapter.
Reconnect the battery.
Turn it on, and it should be "unlocked".
If not, tell us what error-message(s) are displayed.
Posted on Dec 13, 2009
ramesh singh
  • 126 Answers
SOURCE: the touchpad got locked
u can try this all u can do is just go to this website and click on driver detective scan now and then click on the download now and then restart ur computer and then the touchpad should work and still if it doesnt work then uninstall and resintall the touchpad driver and the synaptic drivers and restart the computer and still if it doesnt work replace the touchpad from dell...the website is http://www.drivershq.com/Drivers/VistaDevices/Dell-Input-Dell-Touchpad-Pointing-Stick-Driver/13926/Drivers.aspx ................... thanks
Posted on Jan 22, 2009
  • 29 Answers
SOURCE: Problem with display in DELL XPS M1530
Your video driver crashed. Have you installed a video game or Fusion tv tuner recently. deinstal and reload your video driver. holding down the F8 key while booting go into control mode (which doesn't load drivers) delete app, then load drivers from your CD.
Posted on Sep 10, 2009
  • 95 Answers
SOURCE: dell xps m1530 with intel core duo keeps freezing
To further investigate the issue you may do the following.
1.go to control panel --> administrative tools then select event viewer. check on system logs. you might be able to find a clue on why the notebook keeps on freezing after 15 to 20 minutes.
2.please check your virus definitions if its fully updated. If not please update it then do a full scan afterwards.
3. do a windows update on your system if it's not fully updated yet.
4. You may also check or try to remember what has been installed lately. It might be that the application installed have caused vista to freeze.
Or you may also check this link for another user who has the same issue.
hope this helps . . .
Posted on Apr 05, 2010
  • 551 Answers
SOURCE: My Dell XPS m1530 screen changes to black and white
try changing your desktop.
Posted on Apr 08, 2010
How do I switch on my Dell XPS M1530, black screen
Here is a link to the owner's manual of your laptop which contains info on troubleshooting problems:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1530_owner%27s%20manual_en-us.pdf
Here is a link for the service manual of your laptop:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1530_service%20manual_en-us.pdf
Hope this helps.
Feb 20, 2013 | Dell XPS M1530 Notebook
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
DELL portable XPS M1530 Error Code 0146 Msg = Error Code 2000-0146
you have a missing start up driver try to trouble shoot run windows on f12 promp f2 then asked to run windows run windows.
Feb 04, 2011 | Dell XPS M1530 Notebook
My dell xps m1530 turns on but the screen stays black. Did my screen break?
Connect it to an external monitor with a VGA connection. If the external monitor comes on, yes your screen is broke.
Nov 04, 2010 | Dell XPS M1530 Laptop
Hi My Dell XPS 1530 Screen remains black at startup
hi
if your Laptop is on and your not getting screen the you have to do two thing
1 remove RAM from the motherboard
2 remove CIMOS battery from the motherboard for 10 to 15 mints
then re fix hope fully your laptop will work
Aug 02, 2010 | Dell XPS M1530 Laptop
Dell XPS M1530 Laptop Logo
94 people viewed this question
Alun Cox
