Question about Iomega (32691) Case Cooling Fan
Iomega media drive cooling fan
Iomega media drive overheating as fan not running. When drive is turned on first the fan seems to give a spin but then stops. Can I fix it or where can I buy spare part?
Thanks
    President:
  • 2,692 Answers
You can try cleaning and oiling (light oil, like 3 in one)the bearings on the fan but it usualy doesn't work. YOu can obtain replacment fans from : Match diameter of fan .You can measure it withb a ruler.
Newegg.com  Tiger.com   E-bay.com and ever other computer parts place.
Posted on Jan 17, 2009
How to fix Fan spinning too fast and monitor no signal
If the fan is running fast and there is no display the most likely cause is a GPU failure.
May 26, 2016 | HP Computers & Internet
Hi I have a Sanyo Convection Microwave EM-C5779V and when the timer goes off the fan seems to continue to run and won't turn off when I hit the cancel button and have to turn it off at the wall.Help?
the fan may keep running to keep it from overheating until it cools down, if you let it go and it shuts down eventually should be no problem, maybe 3 to 5 minutes it should shut down. fan running is not dangerous however if it never stops then the fan will wear out
Jan 01, 2016 | Sanyo Microwave Ovens
How do i open the screenplay media box as i need to replace the cooling fan with a new one !
It would probably be a whole lot easier to just buy a cooling pad to set it on. I have a nice cooling pad for my laptop and those things are great. Just a suggestion though. It would save you the work and the time it would take to learn to disassemble and reassemble.
Oct 27, 2014 | Iomega 35039 1 TB ScreenPlay DX HD Media...
Iomega homwe media network drive - How do i map the drive? The Iomega Home Storage Manager is buggy and often canot find the drive.
Simple type the Ip address of the NAS Drive in the RUN window of your windows pc and hit enter.
Now all the shares appears right click the Share u wish to MAP and select MAP network drive.
That is it.
eg:in run type \\192.168.10.177 then replace the 192.168.10.77 with your address.
Jun 08, 2011 | Iomega 1TB Home Media Network Hard Drive...
My Iomega DESK TOP HARD DRIVE FAN HAS STOPPED COOLING
I would blow out with air compressor or canned air completely. If the fan feels tight, i would take sticker off center of fan and spray a little WD-40 in center of fan and work the blade with your hand. After it frees up a bit give her a try. Good luck and have a good day.. Sincerely HDTV GURU JAY
Mar 16, 2011 | Iomega Computers & Internet
My iomega network drive just decided to not show up as connected to my computer anymore. according to my router there is a physical connection, but my compy doesn't see it and the iomega software can't...
Reboot the network drive and the router, this usually works when mine doesn't show. You may need to disconnect any mapped drives, as it may show with a new ip address. Computer may also need to be rebooted.
Dec 07, 2010 | Iomega 1TB Home Media Network Hard Drive...
Iomega hard drives seem to give my MAc finder brain freeze
It's possible that ONE (or maybe BOTH) of the drives are defective. Disconnect one of them, and continue to use your computer. If the "freeze" never appears, then the non-connected drive is defective, and, since it is a "new" drive, you can get it replaced, for free, under warranty. If the "freeze" appears, then the currently-connected drive is defective, and needs to be replaced.
Apr 02, 2010 | Iomega 33089 250 GB Hard Drive
1996 Rodeo overheating
Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Dec 16, 2008 | 1996 Isuzu Rodeo
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Occasional overheating
It is easy to check your fan clutch.With engine off and cool reach in and spin the fan blades.They should move real easy.Also make sure your radiator fins are not super dirty.
TK46
Jul 09, 2008 | 1999 Jeep Cherokee
Iomega (32691) Case Cooling Fan Logo
482 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
