How to modify windows vista to be able to install itunes. I keep getting errors saying my system has not been modified to complete installation
My laptop keeps getting errors when im trying to intsall itunes it says it has not been modified
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Posted on Dec 09, 2012
  • 7,627 Answers
You didn't mention the Make, Model of computer or what OS you have? 32 or 64bit version? You can find new and old versions 32 and 64 bit here: http://www.filehippo.com/download_itunes_32/, The 64 bit version is under RELATED DOWNLOADS.
2 Suggested Answers
SOURCE: Installing Sprint Smartview on Windows Vista --Dell laptop
Smartview is supposed to work with Vista. Did you right-click on the install file and run as administrator?
If you can not get it to work there is a work around.
First, download and install the BlackBerry Desktop Manager software. After installation, plug in your BlackBerry and start up the software for the first time. Open the Options -> Connection Settings… window and set the connection to USB. Plug in the BlackBerry, enter your password if applicable, and Vista will find the device and install a “standard modem”.
Open the Control Panel
Network and Internet
Connect to a network
Set up a connection or network
Set up a dial-up connection
Select Standard Modem
Dial-up phone number is #777
Connect.
Everything should work, some have reported faster speeds using this method over the Smartview program.
Posted on Mar 15, 2009
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Tip
Unknown error 6 ipod touch, iphone, itunes
Error 6:
Following iTunes for Windows: Troubleshooting security software frequently resolves this error.
also may be.....
There may be third-party software installed that modifies your default packet size in Windows by inserting a TcpWindowSize entry into your Registry. If your default packet size is set incorrectly it can cause this error. Contact the manufacturer of the software that installed the packet size modification for assistance.
on Apr 15, 2010 | Computers & Internet
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
How i make a shell pack replacement software like xpize or vista inspirat plz help me....
Hii
well windows XP does not allow you to do that, u need to de-activate the services first which monitors windows system files from getting it changed or modified. The Vista Inspirant or Vistamizer (Google them u wud get the DOWNLOAD LINKS) Both comes with built in deactivator.
While installing XP messages pop's whether to allow the modification of shell files or deny, jus click deny every time when it pops while installing these Vista packs.
NOTE: It is not suggested to change or modify shell files, unless ur very well aware of using such things, it may harm ur OS. Make sure u make a back up before u do so.
Regards
Sep 07, 2009 | Microsoft Windows XP Professional
Want to install Adobe 9 but keep getting Error 1606
Error "1606: could not access network location \Startup" occurs when installing Adobe Creative Suite 4 products or Acrobat (8 or 9)Check out this website for the fix to this issue.
http://kb2.adobe.com/cps/402/kb402867.html
Jul 30, 2009 | Computers & Internet
In trying to install OmniPage SE onto a new computer with the vista operating system, all goes well until I come to the installation of OmniScan SE. I get the message: "The wizard was interrupted before...
Unfortunately, Nuance most likely doesn't have a Vista patch to sort the problem with Omniscan.
The best advice I can give you is to remove Windows Vista from your system and install Windows XP.
Vista is riddled with bugs and incompatibilities with many software packages and has been replaced with Windows 7 which is due to be released soon.
Rather use windows XP until Windows 7 becomes available and save yourself many further headaches.
Let me know if you would like any further assistance.
Best regards,
Graemevm
Apr 28, 2009 | Canon ScanFile OCR Full Version for PC
Connect.
Mar 13, 2009 | Computers & Internet
.MSI not found when modifying exe from control panel
Hi Vijay,
This might be an authentication problem, because added security in vista, please make sure both the systems are authorized to communicate to eachother and those files/folder have the sharing permissions. Alternatively copy that .msi to your systems/system32 folder
Hope It will work
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 29, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to load Roxio Creator 2009. Message says 'wizard was interrupted, your system has not been modified'. My operating system in Vista Home Premium.
During the installation of DirectX 9 portions of Creator 2009, the installation halts, it perhaps tries to roll back, gives an error....wizard was interrupted ... and cannot be completed.
Resolution
Open My Computer (or Computer for Vista users) from your Start menu.
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Creator 2009 and follow the on-screen instructions.
It helped some..
Dec 17, 2008 | Computers & Internet
TRYING TO INSTALL HOME DESIGN & RENOVATION 5.0 COPYRIGHT 2001, I HAVE VISTA OPERATING SYSTEM AND I KEEP GETTING AN ERROR THAT SAYS "OLE REGISTRATION FAILED, UPDATEREGISTRYFROMRESOURCE ERROR 0x80020009"...
try installing by right clicking and then choosing run as administrator... coz some system folders can be modified by the setup only if it has admin permission...
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
