Question about Nordic Track Exercise & Fitness
Nordic track 7 heart rate monitor not working
Monitor giving rates that are not even remotely reasonable. One reading. 66 the next reading 169 then back to. 66 again
r321567499
  • 74 Answers
SOURCE: Every heart rate monitor - replacement battery doesn't work.
This link might be helpful...under the picture of the given product click on "great information about this product" It gives all the specs and troubleshooting ideas. I hope this is helpful.
http://www.heartratemonitorsusa.com/Pages/TRANSMITTERS/T31-coded.html
Posted on Jan 07, 2009
SOURCE: I have a cardio zone heart rate monitor but not the manual.
No further need for assistance.
Posted on Feb 16, 2009
vpaaf
  • 115 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Posted on May 01, 2009
6ylucy
  • 742 Answers
SOURCE: need manual for reebok precision xt heart rate
Hi, find that here:
manualfox.com/link/reebok.htm
Posted on Jan 14, 2010
  • 10865 Answers
SOURCE: heart rate monitor not working
Remove the batteries and clean the battery contacts inside the device with a common pencil. Then insert new batteries that you know are fresh. That should fix it. If it still won't work for you go to Garmin.com and send it in for repair. Joe
Posted on Mar 19, 2010
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
How do you reset cardio track watch
u may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions
    • 1 Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    NordicTrack A2105 console is very faint to read
    It sounds like the upper console has a loose connection ( check wire harness connections in the upper and lower board section ) or the upper console is failing call Icon Fitness @ 1-800-999-3756
    Jun 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
    I need a manual for the Nordic Track Pro's heart/pulse monitor.
    I believe this unit uses a chest strap for monitoring heart rate and the clip you are referring to maybe the safety and the clip attaches to your running apparel. Go to iconfitness.com click on to customer service then parts replacement enter the manufacturer and model name and you should be able to get and manual for this on PDF
    Apr 09, 2010 | Nordic Track NordicTrack Professional...
    Heart rate monitor not working
    Mar 19, 2010 | Heart Interface Garmin 305 Gps Heart Rate...
    Exercise & Fitness Logo
    99 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Electro Med Services...
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
