Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Computer scanned for faults but did not buy solution from microsoft now computer will not boot up
Went clean up and speed up response diagnostic check carried out with so called faults offered solution from microsoft for 50$ standing order however microsoft wanted 50$ every 6 months I disagreed and deleted the programme since then the pc will not boot up it seens that microsoft have infected the PC can this be fixed???????
  • Lenovo Master
  • 7,627 Answers
DO NOT PAY THE MONEY! Sounds like "SCAREWARE" not MS but MALWARE. Boot in safe-mode with networking: http://pcsupport.about.com/od/termss/p/safe-mode.htm?nl=1, Download MALWAREBYTES :http://www.filehippo.com/download_malwarebytes_anti_malware/, in the install MIND the TRIAL PRO version, UNCHECK/UNTICK, you want the freeware version, RUN A FULL SCAN, DELETE ALL RESULTS. Depending on the size of your HDD it may take hours. ALSO RUN A FULL SCAN using YOUR UP-TO-DATE Anti Virus. REBOOT Normally. For further assistance respond to this post.
Posted on Dec 09, 2012
03 kia sedona ex was getting tps code, replaced that with 1 from auto store, although the guy put it on, and messed with idleing it down, van will slowly pick up speed downhill, lose speed up hill
The age of your kia warrants scan of the OBDII Fault codes with a print out (Autozone can do it). The TPS Should not effect engine speed Creeping up or down. Check the codes first to avoid buying parts you don't need. Also don't throw those coils away, the are probably OK. Check out some of my other post concerning drivability problems . Always start with cheapest fixes first.
May 15, 2017 | Kia Cars & Trucks
What does error oxcoooo12f indicate?
There is an error in either an application or a damaged file. Try these;
Method 1:
Boot the computer in a Clean Boot state and check the status. A clean boot helps to verify if any third party application service or startup item is causing this issue.
Note: After you have finished troubleshooting, follow steps under "How to reset the computer to start as usual after troubleshooting with clean boot" in the article to boot to normal startup.
If issue persists, follow Method 2.
Method 2:
If issue persists, I would suggest you to perform SFC scan and check if that helps. The sfc/scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2016 | Computers & Internet
How to speed up a slow booting HP Windows Vista desktop?
lots of things to try, scan for malware/virus remove temp files
run diagnostics to check hardware. hard drive in older machines
if have the disks that came with it and all else fails backup all your data reinstall windows. windows tends to slowdown over time
Oct 08, 2015 | Microsoft Windows Vista Home Premium...
Need to download rt120.bpl
1. When are you getting this error message?
2. Have you made any changes to your computer recently?
3. What is the exact error message you receive?
I would suggest you to follow the steps and check if it helps.
Method 1:
Step 1:
Login to Safe Mode and then check if it helps.
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Step 2: Perform a clean boot and then check if it helps.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
NOTE: Make sure that you perform "step 7" in the link mentioned above to boot your computer normally.
Method 2: Scan your computer for virus using Microsoft Security Scanner and then check if it helps.
Microsoft Safety Scanner
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
Hope this helps.
Oct 10, 2013 | Microsoft Windows 7 Ultimate for PC
Need to download dll file rt120.bpl
Method 1:
Step 1:
Computer wont restart
try booting up in safe mode and run Disk Clean up, and run a Virus scan, and anti-spyware scan, update all system drivers. and scan for disk fragment faults
Jun 23, 2010 | Alcatel Speed Touch USB (3EC18607GA) Modem
Abs light on in my 2005 town and country
The ABS light comes on when the ABS module detects a fault in the ABS system. There are dozens of component failures and open/shorts in wiring that will set the ABS light, ranging from a faulty wheel speed sensor, open/short in wheel speed sensor wiring harness, faulty hydraulic unit, fault electronic brake control module(EBCM), faulty tone ring,etc. There isnt a relay or reset procedure to turn the light off- it can only be turned off by repairing the fault responsible for turning it on, and then using the factory scan tool to erase the fault code and reset the light.
While it is possible the majority of the faults to be repaired at home, the fault codes can only br retreived with a diagnostic scanner with ABS capability. This has to be done first in order to know where the problem is to either repair or do further diagnostics to determine if it is a faulty part or a wiring harness issue. If the problem is in the hyrdaulic unit, this would need to be replaced by a shop as it will require bleeding afterwards with a diagnostic scanner.
I would advise spending the $50-70 to have the on-board computer read for stored ABS fault codes. Considering that most sensors cost that much themselves, you can quickly sink much more than a diagnostic fee into replacing parts based on "what usually goes out" guesses
Hope this helped (remember comment and rated this).
Apr 21, 2010 | 2005 Chrysler Town & Country
I have a 2001 Mercedes C240. When the engine is running with car stopped you can feel a bit of trembling. It also cuts off during driving and at slow speeds only. Like when I will the foot off the pedal...
The first thing you do is have the engine control module scanned for fault codes. I also suggest you buy a can of spray throttle valve cleaner and clean the throttle valve and the idle speed control valve.
Apr 21, 2017 | 2001 Mercedes-Benz C-Class
I do not have a 4th gear, I think my solenoid went out, and also my speed sensor
I would try replacing the speed sensor first. The solenoids are a complete assembly. Most Dodge dealers keep the speed sensors in stock and they are pretty reasonable in price. Have you had anyone run a diagnostic scan of your computer to check for codes?
Jan 12, 2010 | 2002 Dodge Intrepid
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
26 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
