Question about Kitchen Ranges
How do I set the oven on100.
Maytag electric lighting gas range, how do I st he oven temp at 100
    New Friend:
    Problem Solver:
  • 7 Answers
I'm guessing that you want your oven at 100 degrees for drying some food/herbs, or culturing homemade yoghurt. I do all of those, so know the temp range required; 95-110. Most ovens can't be set as low as 100, but the cool thing about a gas range is that the pilot light keeps the interior temperature close to that, and if you keep the oven interior light on, that helps. Get an oven thermometer, costs under $10, test oven temp. If your oven doesn't do it you can get a pizza stone or even a few bricks, preheat the oven to warm the stone/bricks on the bottom rack, turn oven off. Then put in your product of choice on top rack. Leave yoghurt in for 8 hours, leafy herbs (sage, thyme, oregano, etc) for 12 or more hours. If doing yoghurt, don't open door, consistent temp is important. If doing herbs, crack the oven door open slightly with a wooden spoon to allow moisture to escape, critical to drying. I hope this helps.
Posted on Dec 09, 2012
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
  • 492 Answers
SOURCE: Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Posted on Apr 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: electric ignition on a gas oven
The ignitor is probably weak. It glows but is not very bright. Mellow orannge color? Replace it.
READ HOW IT WORKS
Posted on Jun 08, 2009
SOURCE: hook up oven door on maytag gas range
You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
Posted on Mar 04, 2010
aquatom
  • 108 Answers
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
Posted on Oct 08, 2011
Maytag gas range oven wont cycle
it could be the thermocouple . or thermostat .
Feb 09, 2016 | Maytag 30" Free Standing Gas Range -...
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Calibration
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
