Question about Plantronics Hp - Pavilion G6-1B79Dx Laptop / Intel Core I3 Processor / 1
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
    Novelist:
    Champion:
  • 233 Answers
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Posted on Dec 10, 2012
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Power indicator blinking orange and white
Mym7 stops charging the battery every now and then to allow the battery to discharge. This extends the life of the battery and changes the state of the battery light.
Feb 21, 2014 | HP Pavilion dv7-7000 dv7-7023cl B5R45UAR...
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
Won't recognize battery charger
The battery might need to be replaced.  If it works plugged in, but is not charging....it is simply not holding the charge.  I know it seems strange that when it is plugged in without the battery it will not work, but that sometimes is the case.
May 09, 2009 | HP Pavilion dv9000z Notebook
Blinking battery light
Green is charged, Orange is Charging and Red indicates a low charge or a possible weak or defective battery. All modern batteries are controlled by a microprocessor that monitors the health of the cells. Even if the battery is holding a workable charge, it can still be deemed "bad"
If the battery is fairly new you might get a replacement from Dell, if its a year or more old, it could be dying an early but not abnormal death. If more than 1.5 years old, be sure to check the Dell battery recall list as some of these are recalled and you'll get a free battery replacement if its on the list!
-Good luck
Jan 05, 2009 | Dell Inspiron 9300 Notebook
Plantronics Hp - Pavilion G6-1B79Dx Laptop / Intel Core I3 Processor / 1 Logo
152 people viewed this question
Top Plantronics Computers & Internet Experts
David Payne
David Payne
Are you a Plantronics Computer and Internet Expert? Answer questions, earn points and help others
