Question about Shure Ulx1-j1 Wireless Bodypack Transmitter, 554-590 Mhz j1 Wirelesssounds
Ulx1 has no display in window and battery light is red
5 Suggested Answers
  • 611 Answers
SOURCE: Shure ULX1 wireless body pack has good battery but
Remove the battery and leave it out for a couple minutes to see if that helps. Also, check the battery with a volt meter to make certain it is above 8.5 volts. I have seen entire cases of batteries that are defective. If the battery checks to be above 8.5 volts and you have removed the battery for over two minutes, then send the bodypack in to Shure Service (www.shure.com/service)
Posted on Jul 06, 2010
  • 611 Answers
SOURCE: Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Posted on Jul 15, 2010
  • 611 Answers
SOURCE: I have the same problem.
I suggest sending the unit to Shure for repairs. The battery indicator is controlled by the micro. Thus, it needs to looked at by a service center that has access to the micro code.
Posted on Dec 14, 2010
  • 611 Answers
SOURCE: shure ulx1 pack red power
Please make certain the battery is good. Put a voltmeter on the battery to make certain it is above 7.5 volts.
If the battery does measure above 7.5 volts, then then transmitter will need to be sent to Shure for repairs.
Posted on Dec 22, 2010
Er r1 error message on shure wireless body pack
Does the display show something like "E1" or "F1"? See Shure's website at:
http://shure.custhelp.com/app/answers/detail/a_id/2818
Apr 03, 2014 | Shure ULX1 Body-Pack Transmitter...
Can you make a shure transmiter ULX1 work with the shure PG4 receiver??
Sorry, that will not work. They use different companding and noise reduction schemes.
Jan 30, 2013 | Shure Ulx1-j1 Wireless Bodypack...
Shure ulx1 pack red power light will not turn green. Pack display does not show any status messages.
Dec 20, 2010 | Shure ULX Professional Series Wireless...
I have the same problem. The ULX1 bodypack transmitter displays a RED battery light even when I use different batteries. I have used a voltmeter to test the batteries and they are good. I took the unit a...
Dec 07, 2010 | Shure ULX1 Body-Pack Transmitter...
I cannot get my transmitter out of the master list mode. I tried holding the set button down for 10 seconds but the display still reads E000. How can I reset it?
When you press the MODE button, does the display say "FR L"? That means you have the transmitter frequency locked. Instructions on the Frequency Lock are in the User Guide.
Nov 03, 2010 | Shure ULX1 Body-Pack Transmitter...
Shure ULX1 wireless body pack has good battery but Batt light(red) is on and no channel display or output but backlight is lit. Any suggestions
Jul 06, 2010 | Shure ULX1 Body-Pack Transmitter...
I have a shure ULX-1m1 transmitter with full battery but will not work. screen comes up green nothing on the display and the battery light is red, what could this be? and how do I fix it
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Sep 29, 2009 | Shure ULX1 Body-Pack Transmitter...
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
Shure Ulx1-j1 Wireless Bodypack Transmitter, 554-590 Mhz j1 Wirelesssounds Logo
Top Shure Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Shure Radio Communication Expert? Answer questions, earn points and help others
