Question about Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Yamaha 4HP outboard. Cannot pull strter cord - jammed or stuck. Have checked if in neutral - OK. Have removed spark plug and attempted to turn prop but am unable to do so.
Hello I have a 2004yamaha f15ELHC outboard motor GOOD BATTERY IN NEUTRAL PUSH STAT BUTTON and nothing no clicking
Likely a connection issue. Remove, CLEAN and replace all connections. Tighten properly. Could also be a bad starter relay.
Aug 26, 2017 | Clymer Marine Maintenance and Repair...
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
15 hp yamaha not shifting stuck in gear
First, check the linkage under the motor cover. It stoops you from given the engine too much throttle when the motor is in neutral but can jam the system if you try to shift out of gear at too fast of speed. Or a link in that system could be broken/loose. If all looks OK the check your lower unit oil. If none or water, the gear case could be trash.
May 26, 2014 | Yamaha Impeller, 8, 9.9, 15 HP Outboards...
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
I have a Yamaha Grizzly 350 that won't start/turn over.
Check the starter motor on the bench clamped in a vice ,you may have sluggish or worn brushes .
Mar 16, 2010 | 2002 Yamaha TT-R 250
Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Logo
243 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
