Question about Kenmore Refrigerators
Frosty freezer warm fridge. cleened back panel, now what
Defrosted fridge, cleaned back panel. fan works. once plugged back in how long do we wait before fridge should get cold.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
8 hours
Posted on Dec 09, 2012
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
I CLEANED THE INSIDE OF MY REFRIGERATOR TODAY AND NOW IT WONT COOL. THE FREEZER WORKS FINE. I HAD IT OPEN QUITE SOME TIME. THERE IS AIR FLOW INSIDE THE FREEZER BUT NONE IN THE REFRIGERATOR . DID IT FREEZE...
Did you leave the freezer running while you cleaned the fridge? Warm air from the outside latches onto the cold frosty areas and has stopped the fan or auger. Suggest you switch off unit and defrost completely. Then retry.
Sep 21, 2009 | Whirlpool ED2FHSS Side by Side...
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Maytag MBB1954GES not cold. Fresh food area warm, motor not on. Freezer OK.
Check the freezer fan is running with the door switch pushd in by hand, check the back wall of the freezer for frosting if it's frosty check the defrost system eg defrost element, Defrost termination stat and defrost timer. If the freezers running perfect check the fridge difuser/damper and see if it's open this is the part that opens and closes the vent between the freezer and fridge to allow cold air into the fridge. The Damper is up the top left corner of the fridge. cheers.
Mar 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
GE Monogram Fridge/Freezer
A frosty freezer in the back panel is an indication of a defrost failure issue. Problem may lie in the the control board, heater or defrost terminator. The problem usually is a broken defrost element. Hope that helps :)
http://tclaundryrepair.com/
Feb 25, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Warm fridge frosty freezer
Hi. thanks for the question . check the freezer fan motor, is it running . is there frost build up in freezer, check that. pull fridge away from wall. remove back panel .clean all lint . thanks the appliance doc
Sep 17, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Jenn-Air Refrigerator
Might be icy. First, fully defrost by either removing the rear panel and using a hair dryer (dangerous) or leave it off and open for two days. Check door gaskets and clean or repair. Clean condenser coils under the unit. Now, take off the back lower panel and find the compressor. Largest pipe is what we're interested in. Start unit. It will frost the pipe. After 5 minutes, frost should be replaced by ice, dry or wet...not frost. If still frosty, you need freon. Hard to know what the right price would be.
What else could it be? Thermostat, defrost timer. Try my stuff before going on.
Nov 27, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
