Question about Hitachi Televison & Video
Hitach lcd tv dead, no standby light. Power board Vestel 17pw26-1 v4 no signs of burnout/swolen caps.
Have no testing equipment but have changed fuse in plug and checked cable for damage, none found. Have bypassed power switch with no result. Is there any way of (safely) testing power is reaching the board without investing in an ammeter?
  • Hitachi Master
  • 933 Answers
You can pick up a cheap multimeter at radio shack, or Harbor Freight (if one is in your town). Or of you know someone who has a multimeter you could borrow, that would be even better. You will want to set your meter to ac volts, and check for 110vac across the input terminal on the power supply board. I'm willing to bet you have a dead power supply.
Posted on Dec 09, 2012
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
Posted on Nov 11, 2007
  • 6 Answers
SOURCE: ViewSonic N3250W will not turn on
check out this website:
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
I got one of these tvs from a co-worker who didn't want to try to fix it. I stumbled across this brilliant person's work and ordered the small chip from a place in san fran. it was here in 3 days, i carefully soldered in the new chip (not at all easy, be careful not to pull up the contacts on the circuit board when you remove the burnt one) and the tv has been working fine ever since. only $20 with shipping.
Posted on Aug 06, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Power problem with Sony Bravia 40 LCD TV
hello my friend, check the power supply first, probably a fuse,but if the fuses are good you have to call the repairman. ps. i have the same tv brand new in the box with the screen broken so if you need any parts let me know
caypianan@yahoo.com
Posted on May 27, 2009
jrweighing
  • 183 Answers
SOURCE: I have 40? LCD Samsung flat screen TV model:
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
Posted on Oct 17, 2009
SOURCE: Clicking relay no picture no audio no power light red or blue
here is the schematics http://www.scribd.com/doc/33598674/Philips-42mf231d-Chassis-Tpe1-0u-Pa
Posted on Aug 14, 2010
Polaroid FLM1514 LCD power will not turn on
The power supply board 2950c is driven by a Fairchild CM0765 power converter which is a MOSFET combined with PWM controller. This board is used in several different LCD TV's. It should output 15V at 2.5A. You can find a troubleshooting giude here http://www.fairchildsemi.com/an/AN/AN-4141.pdf
If the fuse is not blown, and the 3 output caps are not swollen then usually the capacitor C4 (Vcc Capacitor) is faulty. It is usually a 22uF 35V Electrolytic and you wont easily see if it is faulty - you need a cap meter to test it, or just replace it with a 47uF 50V and it should work.
Jul 08, 2014 | Polaroid Televison & Video
I have a 42" Proscan standby light comes on but the tv wont turn on
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo
Aug 26, 2012 | Proscan 42LA45H 42 in. LCD TV
The tv wont come on the green light just keep flashing
Power supply needs to be first checked:
some information:
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Jun 10, 2012 | Sharp LC52D85U 52 in. LCD TV
Sharp AQUOS LC-32D44U 32 in. LCD TV red light blink once
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_27_2012_5_31_29_pm.jpg5_27_2012_5_31_52_pm.jpg
May 27, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My rca lcd tv dvd combo power light came on but im getting no picture or sound
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_22_51_pm.jpg
May 15, 2012 | RCA L32HD32D 32 in. LCD HDTV
The tv switched off and the lcd light started flashing green
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_12_2012_1_20_07_am.jpg
look at the power board inside the set to see if puffed up caps like these that are bad.
A model number (not indicated here) would be helpful.
Apr 11, 2012 | Toshiba Televison & Video
TV Wont turn on
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_11_2012_5_17_43_pm.jpgTo begin look at power board in set for caps that are puffed up on top like these and are if so---bad.
Apr 10, 2012 | JVC 42 in. LCD TV
Tv no power
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_5_2012_2_41_45_pm.jpg
Look at the power supply board inside the set (follow the power cord inside to it) for caps that look puffed up and are bad like these.
Apr 05, 2012 | LG 42LH30 42 in. LCD TV
ISymphony LC22iH90 22 LCD TV just black screen
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_2_04_52_pm.jpg
Look inside at the power supply board to see if puffed up caps like these.
Apr 02, 2012 | iSymphony LC22iH90 22 LCD TV
Televison & Video Logo
688 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
