Question about Bernina Artista 180
The top thread is balling up on the bottom side of the material - what needs adjusted?
  • Bernina Master
  • 7,365 Answers
Try changing the needle--the tip of the needle could be damaged
turn the bobbin the opposite direction
make sure the top has not come off the thread take up lever
here is a free manual, see if it's the right one for the machine
http://www.bernina.com/getdoc/d4dc2dee-97a4-4987-ac83-14a5e664b42d/Bernette_100_200_manual
Posted on Dec 10, 2012
3 Suggested Answers
  • 9 Answers
SOURCE: burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Posted on Jul 17, 2009
  • 166 Answers
SOURCE: something is wrong with bottom thread. It makes a
First check that your needle isn't bent - it sounds like it may be dragging against the back of the hook. Dont 'pull' the material through - let the feed-dogs do that. Probably best to get it checked-out by a competent Bernina agent
Posted on Oct 17, 2011
The thread balls up on the bottom side, it looks like the foot is not moving the material
Frequently, the top thread is not seated in the top tension disk and it is causing thread nesting (or bird nesting).
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Re-test your machine.
It may help to install a brand needle.
Also, avoid old or bargain bin thread.
If the mess is under the fabric, the issue is the top thread.
Jul 27, 2017 | Sewing Machines
My Elna sewing machine is sewing very loosely and it is very messy on the bottom side of my material, why?, and how can i fix it?
When your bottom thread is messy it is the top thread needing adjustment. Your machine may not be threaded properly and the thread may not be sitting correctly between the tension discs.
Check to make sure your machine is threaded correctly.
Check thread between the tension discs.
After checking, adjust the tension (tighter) and do a test. If it is still messy add some more tension and do another test.
Jul 10, 2017 | Elna Sewing Machines
The thread balling up after a few stitches. What needs to be adjusted?
balling up under material ( birdnesting) is from the needle thread tension not tight enough
using scrap material keep adjusting until the threads meet at the center of the materials
may need to be readjusted for different thread thicknesses, materials and needle eye sizes
Apr 15, 2017 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
The thread on my Janine3-18 is getting tangled on the bottom of tho sewing
usual if thread tangles on the bottom is that you top thread tension need adjusted try on a piece of scrap material and adjust your tension until the stitches are even top and bottom hope this helps you
Feb 11, 2015 | Sewing Machines
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
Why does my thread ball up on the bottom side of my material when I try to sew?
Usually when your bottom thread is messed up, it is because your top thread is not threaded correctly.
Jun 27, 2014 | Brother XL-5500 Mechanical Sewing Machine
The bottom stitching looks like a line and not stitches the top stitching is fine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
Bottom tension to tight
I found that sewing this type of fabric you should not have any pressure on the presser foot. and the top tension should be looser but note the tension before you adjust. and remember to make sure the needle is the right size for the fabric. and since wer are not to change the bottom tension because it always right?? then you may have to make the seam stitch longer good luck
Feb 23, 2009 | Consew 226R-1
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
